Fail sudo fwupdmgr update Bluebird Samsung 4 PopOS
Hi all, when running command sudo fwupdmgr update
  • The settings in PopOS also displays a similar error.
  • I’m using PopOS encryption
Please advise.
I get the following error:
failed to write data to efivarfs: Error writing to file descriptor: No space left on device
I can’t add more images yet… new user :frowning:
I’m using popOS Encryption
System details
The firmware doesn’t currently support updating the UEFI dbx separate from the main firmware
Thank you for getting back to me so quickly. :+1::heart: I see. Does that mean I should wait till an official release comes out from chrultrabook? @MrChromebox
Chrultrabook doesn’t release firmware, I do
Okay, that’s fair. Thank you for everything your doing for the Chromebooks. :folded_hands:
