"Factory Error: malformed Hardware ID" After Restore to Stock ChromeOS [SOLVED]
After using Linux on an HP Chromebook 14 N400 (BLOOGLET), I wanted to restore it for a profit (they usually go for around 120 as I got mine for 60), and because I had used a generic recovery media, my HWID was set to probably a default setting: ABC-123-XYZ-456, there are other posts about this without much traction. Any way someone could generate me a HWID, or give me steps to find mine in some way?
only google can generate them (correctly). If you didn’t backup your stock firmware, your HWID is gone. Best you can do is use someone else’s for the same board and hope it doesn’t end up breaking something
BLOOGLET C2B-A6D-B2K-T3R-N3A-A4K
try this
it worked! I tested in dev mode and normal mode, thanks for the help.
