MrChromebox Firmware Utility Script starting up
Downloading supporting files…
Downloading required tools…
flashrom v0.9.9 chromiumos/third_party/flashrom - Git at Google : c329008 : Oct 28 2017 12:29:02 UTC on Linux 6.12.43-chromebook-brunch-sebanc (x86_64)
Getting device/system info…
Flashrom is unable to read current firmware; cannot continue:
You may need to add ‘iomem=relaxed’ to your kernel parameters,
or trying running from a Live USB with a more permissive kernel (eg, Ubuntu 23.04+).
If you have UEFI SecureBoot enabled, you need to disable it to run
the script/update your firmware.
MrChromebox Firmware Utility setup was unsuccessful
- diagnosics report has been saved to /tmp/mrchromebox_diag.txt
- go to https://forum.chrultrabook.com/ for help
I’m running on ChromeOS with Full ROM, btw. Board name is MAGISTER, although, chromeOS thinks its BRUNCH since i am booting ChromeOS with BRUNCH on the full uefi rom. I already added iomem=relaxed to the kernel parameters. Secure boot is off.
