Enabling Developer Mode on Asus Chromebox 3
I have a Asus Chromebox 3 (CN65) that I bought off from eBay. It currently is not org-managed.
I would like to enable developer mode, in order to flash a UEFI compatibe firmware via mrchromebox.tech.
My problem is that after removing the write-protect screw, when I enter recovery mode, nothing happens when I press Ctrl+d. No prompt is shown, the display doesn’t change a bit. No confirmation screen is shown. I tried multiple keyboards, but it did not do any difference.
I tried pressing the recovery button as confirmation, but that did not do anything either.
Is this normal? What am I doing wrong?
What should I try differently? Should I do a factory reset, and retry?
it’s a firmware/keyboard compatibility issue, nothing you can do other than find one that works, or flash the firmware chip directly using a ch341a USB programmer
Thanks for your help!
I will try my other keyboards too, and report back.
Thanks for your efforts in making all this possible!
My SUN Type 5 USB keyboard came to the rescue!
With that, the Chromebox picked up the Ctrl+d keypress, and showed me the confirmation prompt.
With that I was able to turn off OS verification!
chromeoson
