hii, i have acer chromebook spin 514 (i3-1110g4) (voema) , i checked that it’s supported by the firmware in ‘‘view status’’ section but when i searched for in ‘‘install’’ section i don’t find my cpu(i3-1110g4) i when i tried too install the firmware i couldn’t install it (no such file or directory) … please i really need help
Have you enabled developer mode?
Have you disable write protection and then gone into terminal to download and install custom firmware?
Be sure to run through the guide.
Please let MrChromebox know that your device doesn’t have a ROM for it and let CoolStar know that her install helper website is missing instructions for your device. Easily fixed most likely, just have to ask.
