I tryed to install windows 11 on my c640 g2 the it shows after all the procedure installation failed
if your Elemi has eMMC, you’re out of luck as Windows doesn’t support the GL9763e eMMC controller used on that device (no drivers exist for it). Linux works perfectly fine however.
