Is it possible to dualboot Chrome os and windows?
hp c1030
hp c1030
Dual booting ChromeOS and Windows on a Chromebook is only supported in the same way that you can dual boot on a regular PC. This is beyond the scope of this project and you may want to check out Brunch and linuxloops. Brunch also has a subreddit.
Please note that you will have to flash MrChromebox’s full UEFI firmware first, regardless, and that it is generally best practice to install Windows before attempting to install ChromeOS.
So if i understood you right:
I already have chromeos, i have to
No way to keep the official chrome os and add windows?
That is completely correct! I’m glad you understood what I was trying to say.
No, unfortunately.
Thank you!
I’m pretty happy with chromeos , but as always some apps demand windows.
Reverting from MrChromebox’s firmware is possible?
Yes, reverting to stock firmware is possible. Instructions on how-to are on this page of the docs: Reverting to Stock chromeOS | Chrultrabook Docs
Thanks again, everything is clear now
mrchromebox site is down ?
