Drivers in Chromebook Samsung 3 (BLUEBIRD) does not work
The drivers that i so tried to install on my Windows 10 (or 11) does not work. Apparently i have to use RW_Legacy cause FULL ROM is so hard to install on my Chromebook.
Where did you get the idea of full rom being hard to install?
The Samsung Chromebook 3 is CELES, not BLUEBIRD. BLUEBIRD is the Chromebook 4.
this statement makes no sense
Actually, I was talking about the Samsung Chromebook 4 (Bluebird), and I’m having issues with the drivers not working on it. I was wondering if there’s a solution for this since the drivers don’t seem to be functioning properly on this model. Let me know if you have any insights!
Hey! I found it hard to install the full ROM because the screws on the metal cover (the one protecting the battery wire) were screwed in really tightly. It made it tough to get everything apart and access what I needed. Maybe that’s just my experience, but it definitely slowed things down for me.
It is impossible to diagnose your issue(s) with this level of vagary.
