Does not work with Acer Chromebook 317 :(
I bought a used Acer Chromebook 317 CB317-1H-C3YA
with an Intel(R) Celeron(R) N5100 processor @ 1.10GHz (threads: 4, 2.800 GHz)
When I enter the command
cd; curl -LOf https://mrchromebox.tech/firmware-util.sh && sudo bash firmware-util.sh
Everything is fine until I show the list.
Device: Unrecognized Device
Board Name: QWERTY
Platform: (unrecognized)
FW Type: Stock ChromeOS w/RW_LEGACY
FW Ver: Google_Magolor 13.606.710.0 (11/08/2024)
FW WP: Disabled
  1. Install/Update RW_LEGACY Firmware
  2. Install/Update UEFI (Full ROM) Firmware
  3. Set Boot Options …
  4. Set Hardware ID …
Both points (1-2) are disabled. I can’t enter 1 or 2.
When I reboot, it says it can’t find another bootloader.
I don’t know what to do :frowning: And I want to run Linux Anti-X on it.
Chrome OS Version 142.0.7444.147
when you exit the script, it generates a diagnostic file. pastebin that file and link it here
mrchromebox firmware-util diagnostic report
Tue Jan  6 20:38:55 CET 2026
[deviceDesc]
Unrecognized Device
[device.override]
[deviceCpuType.Name]
(unrecognized)
[fwDate]
11/08/2024
[hasUEFIoption]
false
[isUnsupported]
true
[device]
qwerty
[firmwareType]
[_hwid]
qwerty
[lsb-release]
CHROMEOS_ARC_ANDROID_SDK_VERSION=33
CHROMEOS_ARC_VERSION=14390219
CHROMEOS_AUSERVER=https://tools.google.com/service/update2
CHROMEOS_BOARD_APPID={E0DD1258-E890-493E-ADA3-0C755240B89C}
CHROMEOS_CANARY_APPID={90F229CE-83E2-4FAF-8479-E368A34938B1}
CHROMEOS_DEVSERVER=
CHROMEOS_RELEASE_APPID={E0DD1258-E890-493E-ADA3-0C755240B89C}
CHROMEOS_RELEASE_BOARD=dedede-signed-mp-v57keys
CHROMEOS_RELEASE_BRANCH_NUMBER=41
CHROMEOS_RELEASE_BUILDER_PATH=dedede-release/R142-16433.41.0
CHROMEOS_RELEASE_BUILD_NUMBER=16433
CHROMEOS_RELEASE_BUILD_TYPE=Official Build
CHROMEOS_RELEASE_CHROME_MILESTONE=142
CHROMEOS_RELEASE_DESCRIPTION=16433.41.0 (Official Build) stable-channel dedede
CHROMEOS_RELEASE_KEYSET=mp-v57
CHROMEOS_RELEASE_NAME=Chrome OS
CHROMEOS_RELEASE_PATCH_NUMBER=0
CHROMEOS_RELEASE_TRACK=stable-channel
CHROMEOS_RELEASE_UNIBUILD=1
CHROMEOS_RELEASE_VERSION=16433.41.0
DEVICETYPE=CHROMEBOOK
GOOGLE_RELEASE=16433.41.0
[boardName]
QWERTY
[dmidecode.device]
magolor
[swWp]
disabled
[wpEnabled]
false
[fwVer]
Google_Magolor.13606.710.0
[deviceCpuType.id]
UNK
some idiot tampered with the HWID, which breaks the script’s ability to detect the device.
‘querty’ is not a valid HWID.
The likely correct board name for your device is MAGPIE. Use the script’s HWID function to set your HWID to: MAGPIE TEST-ABC-123
reboot, and re-run the script. ChromeOS will likely complain about the HWID (as it did previously).
Thank you so much for your help.
After installing mrchromebox, I turned off my laptop.
It was off for about 10 minutes because I decided to download a new version of Linux Antix. I created a flash drive using Rufus.
When I turned on the laptop, only the keyboard lit up for a long time.
And the screen was black.
But it must have reset itself, and everything was fine after that :slight_smile:
