Disabling WP on an acer 515 (issue) Same for 315
Troubleshooting
I have modded chromebooks before and know how to do it so I’ll be quick here…
If I remove the battery which I have to do to disable the write protect for this model, I cannot boot the chromebook. AC power with the battery will not turn the machine on, but it boots fine w/ the battery in. I am losing my mind trying to turn this thing on.
My AC adapter is 45w and the listed voltages are 5V/3A,9V/3A,15V/3A,20V/2.25A
the chromebook says on its back its rating is 3a,15v and the seller of this off-brand adapter has the 515 listed as supported, which I am sure it is as it charges the machine fine.
BUT they make 65w chargers for the 515, so is this simply a power delivery issue? Or are there some keys I can press to try and get this thing to boot? Thanks,
edit: same thing but for a 315 which is definitely 45w… won’t boot
OKAY I FIXED THE ISSUE MYSELF, HERE IS THE SOLUTION, MRCHROMEBOX PLEASE NOTE THIS:
  1. had to turn on chromebook WITH battery inside and plugged into AC, enter VT-2 and attempt to run the script which told me it was WP and needed to reboot. I then removed the battery WHILE the machine was powered on and hit YES to reboot. It actually turned on without the battery plugged in and I proceeded to successfully flash the firmware.
I get this is old, but what script did you run that asked you to reboot?
The firmware script
Dude, you saved me here! I was going out of my mind with this problem for over a day, but your solution worked great! Thanks for “thinking outside the box”!!
