Dell Chromebook 3380 Audio Driver
I purchased an audio driver for dell Chromebook 3380 and still having no sound after installing,
From device manager shows that coolstar SST Audio (WDM) cannot start (Code 10)
Please help
I just ran into this. Make sure you upload the signed license in the GenLicense program and reboot.
If you don’t know what GenLicense is then shame on you for not reading the ReadMe. Anyway, see instructions below.
Go into the ‘gui’ folder
Run ‘GenLicense’
Click Generate Unsigned License
Save the file
Go back to GenLicense
Click the next box that says Open License Portal
Login
Click the license under Purchased Licenses
Click Choose File
Select the one you saved earlier
Put a device name in the box
Click Submit
You should then get a signed license file
Click the last box, ‘Select Signed License’
Find the signed license you just downloaded (probably in the Downloads folder)
Click Open
Reboot and it should work.
