Thanks to the people behind these chrultrabook/mrchromebox projects to give our chromebooks an extended life.
I am multi-booting RW_LEGACY on hard disk with ChromeOS and Fedora. Got audio working thanks to WeirdThreeThing.
My Dell has emmc onboard. The emmc stats say that wearoff after 5 years is normal [10-20%]. However loading the kernel/initrd takes almost minutes.
The grub console size is also of the WindowsXP era - I could stretch it max to 1024x768. At least it shows the multi-boot options that I had installed [fedora and chromeOS brunch].
Just to compare what works and what not.
On fedora touchscreen and keyboard mappings do not work yet.
Try to find out why not. In ChromeOS elants_i2s [ELAN touchscreen] is reported by dmesg working well. Under fedora:
❯ sudo dmesg | grep elants
[ 7.434959] elants_i2c i2c-ELAN0001:00: supply vcc33 not found, using dummy regulator
[ 7.435035] elants_i2c i2c-ELAN0001:00: supply vccio not found, using dummy regulator
[ 8.504650] elants_i2c i2c-ELAN0001:00: nothing at this address
lsmod does not show specific kernel modules loaded for touchscreen:
❯ lsmod | grep i2s
❯ lsmod | grep hid
i2c_hid_acpi 12288 0
i2c_hid 45056 1 i2c_hid_acpi
And kernel modules related to touchscreen found in fedora:
❯ ls -lR /lib/modules/6.8.11-300.fc40.x86_64/kernel | grep touchscreen
drwxr-xr-x. 2 root root 4096 Jun 5 17:55 touchscreen
/lib/modules/6.8.11-300.fc40.x86_64/kernel/drivers/input/touchscreen:
-rw-r–r–. 1 root root 14288 May 26 07:00 usbtouchscreen.ko.xz❯ ls -lR /lib/modules/6.8.11-300.fc40.x86_64/kernel | grep elants
-rw-r–r–. 1 root root 15008 May 26 07:00 elants_i2c.ko.xz
Note that on chromeOS the kernel module elants_i2c.ko was not found. I assumed it is included in the kernel, as in lsmod it is also not reported as a specific loaded module.
Then I found this 2020 bugzilla bug with a fix, that work on another laptop.
The trick is to rebuild the kernel and have the elants_i2s run as a loaded module. In this way there is no race condition with other stuff like vcc33/vccio power supply not ready yet.
Any links to a kernel build tutorial is appreciated!
