Hi @coolstar is possible set a fixed value for the backlight? I have a morphius chromebook and
I would like autostart with the lowest or off value.
Thanks.
Thanks.
May be run a command line at windows startup?
I not have idea what is the executable file.
you can do that by using ectool which can be found in C:\Program Files\crosec .after navigate to the location open cmd there and type pwmsetkblight 0-100
if you to run it on start up make a shell command and you have to add the ectool to the path folder in advance system.
Tomorrow i will test. Thanks you.
Your Trackpoint working fine?
Yeah working with the latest build.
“C:\Program Files\crosec\pwmsetkblight x” works but only about 1 second, if kill crosecservice then desired value is set but shortcut keys (ctrl + alt + *) are disabled.
