I am only able to run sudo commands through VT2 but i cannot copy and paste or use capital letters for the exact command so i write -lo, whenever i write the command it says curl(2) no URL Specified! I am so confused.
Could you share a photo of the terminal when trying to type the command?
It should look exactly like this:
cd; curl -LO mrchromebox.tech/firmware-util.sh && sudo bash firmware-util.sh
Also, is Shift key working on ChromeOS desktop? Trying to exclude hardware failure.
It’s -LO capital O as in “oh” not the number 0
If that doesn’t work, try -LOk
Sorry for the late reply i didnt see the email, i reset the chromebook but basically my issue is i cannot use caps lock. It works fine outside of vt2
I know but i cannot use my caps lock for this, i know a lowercase “o” would refer to a file not a link but my caps lock even with an external USB keyboard does not work on vt2
you won’t be able to use capslock in VT-2, hold shift
Thank you so much!
