I have 2 ASUS Chromebook with me, the one with remove battery in order to remove protection, but after i remove battery and Boot to developer and try to run the command on VT-2 shell i do end up with this error (curl: (28) SSL connection timeout) ANY SOLUTION
Make sure you have internet. Entering developer mode disconnects you from wifi and you have to connect to it and enter the password.
My internet is on and working, what i think is the internet is not running inside ctrl +alt+ f2,
Is there anyway i can enable internet there
that doesn’t make sense and isn’t a thing
SSL issues can happen when your clock is set wrong, can you try connecting to a website in chrome to make sure the issue is not with your network config?
