CSAUDIOINTCSOF GUI will not generate unregistered license file
I’ve successfully installed Windows 11 on ASUS C436FA i7-10510U.
I’m trying to create the unregistered license file for Coolstar SOF Intel Audio driver. However, the downloaded CSAUDIOINTCSOF GUI will not generate this unregistered license file… it does not even open a window to choose a save location for the file.
Can you please advise how to overcome this fault?
Thanks.
Anyone solved this problem?
