Crota360/Brya: Rotation/Tent Mode Not Working in Windows 11 26100.7623/.7705
I also have a brya-based chromebook (Dell Latitude 5430 Chromebook 2-in-1, crota360/brya) that no longer has the Chromebook EC Sensor Hub appear in device manager, even after a clean installation of Windows 11 IoT Enterprise LTSC 2024 and trying to reinstall the crosec 2.0.6 driver package. Weirdly enough, across every distribution of Linux I have tried so far (assume latest for all listed: Linux Mint, Ubuntu, Pop!OS), rotation did not work there either.
Keep in mind… The sensors did work in Windows and all linux distros on the 11-30-2025 build of the mrchromebox firmware. After updating, the sensor hub appeared to stop being presented.
I don’t think this is an OS issue, it could be a problem with how the firmware exposes ACPI\VEN_GOOG&DEV_0006. I have all drivers installed including TB4/Audio and applicable chipset drivers installed.
@bookofchrome Redrix is fixed: accelerometer is not working in redrix · Issue #879 · MrChromebox/firmware · GitHub . If what I proposed was indeed what fixed it, it should apply to all affected brya boards.
I suppose MrChromebox will have this fix included for all boards in the next build.
Thank you, everyone! All brya boards affected seem to be fixed in the latest 2603 release. If you’re having issues, ensure you’re on the latest firmware version.
