Greetings,
I recently received two chromebooks, one of which is a Dell 5430 Chromebook CROTA. I followed the steps to install corebook and have installed Linux. I originally saw some drivers issues in the logs when booting to Arch so I went ahead and tried Mint to see if what drivers it could detect.
I am seeing the same errors when I run dmesg | grep error on a free install. Any guidance on what I should do next is appreciated.
[ 0.288303] pcieport 0000:00:07.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.288803] pcieport 0000:00:07.1: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.289303] pcieport 0000:00:07.2: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 1.293227] cros-ec-spi spi-PRP0001:00: Cannot identify the EC: error -110
[ 1.293519] cros-ec-spi: probe of spi-PRP0001:00 failed with error -110
[ 1.978919] cros_ec_lpcs GOOG0004:00: Transfer error 1/3: -95
[ 1.980767] cros-ec-keyb: probe of GOOG0007:00 failed with error -95
[ 3.918134] sof-audio-pci-intel-tgl 0000:00:1f.3: error: sof_probe_work failed err: -2
Before, I was just troubleshooting the post-install audio and I tried the WeirdTreeThing audio setup script before. The audio did not work even though the script ran without any annouced errors. Which is when I noticed that the cros-ec-spi driver raised an error.
Also here is the machine output for lsmod | grep cros
Module Size Used by
cros_ec_sensors 12288 0
cros_ec_sensors_core 20480 1 cros_ec_sensors
industrialio_triggered_buffer 12288 1 cros_ec_sensors_core
kfifo_buf 12288 2 industrialio_triggered_buffer,cros_ec_sensors_core
industrialio 126976 4 industrialio_triggered_buffer,cros_ec_sensors,kfifo_buf,cros_ec_sensors_core
cros_usbpd_logger 16384 0
cros_ec_sysfs 12288 0
cros_ec_chardev 12288 0
cros_usbpd_charger 24576 0
cros_ec_sensorhub 36864 1 cros_ec_sensors_core
cros_ec_debugfs 16384 0
cros_ec_dev 12288 0
cros_ec_typec 40960 0
cros_usbpd_notify 20480 2 cros_ec_typec,cros_usbpd_charger
cros_kbd_led_backlight 12288 0
cros_ec_lpcs 20480 0
cros_ec_spi 24576 0
cros_ec_keyb 24576 0
cros_ec 20480 2 cros_ec_lpcs,cros_ec_spi
matrix_keymap 12288 1 cros_ec_keyb
typec 106496 2 cros_ec_typec,intel_pmc_mux
