CRAASNETO - Ctrl+L doesn't work for RW_LEGACY booting
I was able to flash the RW_LEGACY payload successfully, but when I press Ctrl+L on the developer mode boot screen, it beeps once and says “Something went wrong launching the alternate bootloader”. I can still load edk2 and boot Linux successfully through the “Select alternate bootloader” menu. I’ve attached the firmware log. It seems like Ctrl+L is trying to boot “bootloader #0”, which doesn’t seem to exist?
This is CRAASNETO - Alder Lake-N
Firmware log
Updating storage controller failed.
Found SDHCI at 1:0.0
ui_loop_impl:  menu item
ui_display: screen=0x300, locale=0, selected_item=3, disabled_item_mask=0x0, hidden_item_mask=0x0, timer_disabled=1, current_page=0, error=0x0
ui_menu_navigation_action: Pressed key 0xc, trusted? 1
CBFS: Found 'altfw/list' @0xf24c0 size 0x28
payload_get_altfw_list: Supported alternate bootloaders:
   1 edk2            altfw/edk2      edk2 UEFI bootloader
developer_boot_altfw_impl: Try booting from bootloader #0
CBFS ERROR: 'payload' not found in 'RW_LEGACY'
Could not find 'payload'.
payload_run_altfw: Could not find default altfw payload
payload_run_altfw: Could not find bootloader #0
developer_boot_altfw_impl: ERROR: Alternate bootloader failed
ui_display: screen=0x300, locale=0, selected_item=3, disabled_item_mask=0x0, hidden_item_mask=0x0, timer_disabled=1, current_page=0, error=0xa
ui_display: Something went wrong launching the alternate
bootloader. View firmware log for details.
same thing happens if you click the alternative bootloader menu and select edk2 from there?
Selecting edk2 manually works fine, it’s just the shortcut that doesn’t work.
This is really just a minor annoyance
I can fix that easily enough
updated - same filename/date, just re-run the RWL update
Thank you. Ctrl+L works now
