Finally! in Arco linux the sound now works!!YAY!!!
I feel like @propio1225 is using the audio thing as an excuse to distro-hop
?? False accusations?anyway i just broke arco linux with sudo pacman -Syu which also happened to endeavouros. Even arch is broken.
You can install NixOS next if you want.
My Arch-obsessed friends would always laugh at me when something broke and told me to check the news before updating Arch Linux - News
Ok I will be sure to.Some how it now works(I think)when I use the update button on the ML4W setup for arch Linux(I still use Arco linux).
Hi.
I have the same laptop, and i tested a lot of linux distros. The sound works perfectly with linux mint 21.3. With manjaro 23.1, it works but it has a lot of options when i want to adjust the volume. In debian 12 (interestingly) i have sound in the laptop speakers if i plug a headset in the jack.
Hope it helps.
