I purchased an audio driver for my Asus C214M chromebook but it doesn’t work, it shows code 10 in device manager
you’re missing a ton of other system/device drivers, you can’t expect audio to work when other related things are missing
but I installed all the drivers that were on the website
well, that’s not sufficient obviously. Use Snappy Driver Installer Origin to install only the missing drivers (don’t update/replace any already installed)
Everything works, thank you!
