Constant reboot after removing RW protect screw
The device is Asus C302C Cave,
After removing RW screw - constant reboot.
I’ve tried attaching the screw back, no difference.
The only thing that it allows me to do is to reset it using esc-reset-power, but after reset - nothing happens…
Any help will be appreciated.
removing the WP screw alone wouldn’t cause the behavior you’re describing, something else had to have happened / is causing the issue
