Chromebook unenrollment
I had gotten a Dell Chromebook 11 3189 Model p26t from a storage unit and I wanted to install windows on it but it was managed by a organization and I have no idea how to unenroll since I tried power washing it using a usb to reinstall chrome os and I’m pretty much just stuck how can I unenroll it?
treat the device as bricked, and flash it using a USB programmer as per the documentation on my site
I’m kind of stuck, I see some pages on your website where I require dev mode for some things and some parts where I need a unmanaged Chromebook is there anywhere specifically I should start?
You can find cheap CH341A programmers with the clip on Amazon for anywhere around $15 to $40 bucks Canadian, depending on the bundle you get. You can also find them on places like Alibaba, Banggood, or eBay for cheap. all you need aside from the the clip, programmer and the actual firmware binary itself is a Linux machine or Raspberry Pi running flashrom if I recall.
