Chromebook Stuck in Boot Menu
I recently tried to switch my Chromebook to windows 10. But I believe ive made a terrible mistake. Im stuck in the boot menu and dont know what to do.
how exactly are you “stuck”? We can’t tell you what to do based on “stuck”
But if you’ve flashed the firmware, your next step is to boot and install your OS from USB – per the instructions.
