Chromebook managed by organization
Hi, everyone!
My town’s school is selling really cheap used Chromebooks, and I thought about getting one to try install another OS on it, but apparently, Chromebook says it’s managed by organization! Is there any problem with it?
Question may sound dumb but I preffer to be secure about it rather than buying something that I won’t be able to use/format at all.
Thanks for the help!
You can’t mod a Chromebook that is managed by an organization. Maybe you can if you unenroll it or directly flash to the firmware chip.
Yes, externally flashing is your best bet.
