I have successfully installed RW_LEGACY using firmware-util script.
I am trying to add a boot option in this alternate firmware.
I have located the grub file that works and boots Ubuntu Cinnamon 22.04
<x86_64-efi>
grub.efi
This works when using “Boot From File” in Boot Manager.
However, when i try and add this as a boot option i can select the same grub.efi file but cannot add a description/title, So when i save the edit the option does not appear under Boot Options.
Does this mean we cant make changes using the RW_LEGACY firmware?
Sorry, I am quite a rookie in this stuff
But yet there was another thing up in my mind
I Can still see Some of the default boot options which always remain there (verified image A,B…)
I was wondering if i could get to know the location of boot files they are referring to and if i could create symlink(or just copy paste ) of my own boot files
Could that be possible (Again "Sorry if this sounds stupid, I am a newbie )
That’s just GRUB. You can freely edit grub entries. “Verified image A/B” comes from ChromeOS’ EFI partition. I’m not sure why you didn’t replace it when you installed a Linux distro, since it doesn’t really do anything.
I still have my linux installed
Can you assist me replacing it with grub of my choice
EDIT: I just mounted the efi drive and copy pasted my /boot/efi/ to it and it was done
Hi, is the lack of NVRAM support for RW_LEGACY also why I lose the EDK2 firmware after going through Chromebook Recovery process. Is there a way to prevent this (other than stop using Recovery )
I’m trying to learn all about firmware process etc. but so far not sure U-Boot will be able to boot USB so totally reliant on EDK2 .
Recovery overwrites the RW sections of the firmware to stock, including reverting the RW_LEGACY portion to whatever Google’s implementation is for your board. Most of the time the stock RW_LEGACY doesn’t do anything/is missing basic functionality (whether it’s U-Boot or Tianocore or whatever), which is why you have to flash MrChromebox’s EDKII payload in the first place.
