I installed PopOS with jumper method but I’m stuck with no audio problem. I tried to install audio script but its not working. Can someone help me please?
Have you opened pulse audio manager and checked if it can select a sound card through there? If you don’t have it installed, run
Sudo apt install pulseaudio
Open it and set to pro mode in config, then go to ‘output’ and select your card!
It should work after, if it doesn’t please let me know:D
Pop!os is Ubuntu based and Most Ubuntu based oses have built in audio compatibility through pulse!
I hope I helped ^^
Thank you for the unhelpful steps.
Oh…sorry :(( I was just trying to be helpful I didn’t mean to be ignorant or anything :C
“Pro Audio” is a feature of pipewire that exposes each playback/record device of a sound card even without a profile. In the case of chromebooks with complex codec setups, you may have working speakers but not working headphones. You may not have a working mic. If your device has smart speaker amps then you may also not have working speakers. In all cases, outputs/inputs will not be labeled, outputs/inputs will not auto switch based on if a headset is plugged in or not, and any unused outputs/inputs will not be hidden. It is always better to use a UCM profile which defines how to control the codec and provides human readable names to outputs/inputs. If the UCM is not working for you, the debug script steps written in the docs will generate a collection of logs to figure out why it isn’t working.
I finally did it. I installed LMDE and installed pavucontrol app. That solved my problem.
Thank you so much. I fixed sound issue.
i tried it said it found my sound speaker but sound doesn’t work I even tried it in different distros but it does the same thing in fedora it said apt not found so I changed it to dnf it still did the same thing can someone help? it doesn’t work even on my different Chromebook (Acer Chromebook spin 511) still doesn’t work (same thing).
Try to install Linux Mint Debian Edition and install “pavucontrol” from app market. Then you had to open Pulse Audio Control and select “Pro Audio” profile from configurations menu.
