I’ve installed void linux on the system and the touchpad doesn’t work. It will only work IF I press and hold while dragging for some reason
It’s an ELAN touchpad and i looked into dmesg | grep elan
. Output
7.841159] elan_i2c i2c-ELAN0000:00: supply vcc not found, using dummy regulator [ 7.849240] elants_i2c i2c-ELAN0001:00: supply vcc33 not found, using dummy regulator [ 7.849316] elants_i2c i2c-ELAN0001:00: supply vccio not found, using dummy regulator [ 7.849426] elants_i2c i2c-ELAN0001:00: nothing at this address [ 7.958665] elan_i2c i2c-ELAN0000:00: Elan Touchpad: Module ID: 0x0094, Firmware: 0x0004, Sample: 0x0004, IAP: 0x000e
