Chromebook 11 3120
I boot into a live Linux mint and run the script. For intention to clean the nvram, and after that I run the install/update firmware and turns “error with cmd” failed*, and clean again the nvram the same error and failed.
I was trying to follow the guide on the sticky note in a reddit post to restore the windows 10 installed before from first owner, turns out it bricked my device and wont turn on only led indicator charging and wont show led when charger unplugged. Tried all the refresh and hard refresh combination. Remove battery. Long press.
so after getting an error, rather than saving the log and posting here, you tried to do something else, got another error, and then rebooted?
I’m not sure what you’re looking for here
Is it possible to restore it using usb programmable ch341? Thank you.
yes, that’s what the unbricking instructions are for
