CHELL (HP Chromebook 13 G1) eMMC upgrade
I de-soldered the 32GB eMMC (Samsung KLMBG2JENB-B041) and replaced it with a 128GB chip (Kingston EMMC128-TY29-5B111).
It doesn’t show up in the UEFI boot menu or Shell.
Running MrChromeBox-4.21.1
Does anyone know if I need to edit the firmware to allow it to recognise a different eMMC?
Does linux see it if you boot from usb?
Not that I can see, here’s the dmesg output just in case I missed something:
Summary
To run a command as administrator (user “root”), use “sudo ”.
See “man sudo_root” for details.
mint@mint:~$ dmesg
[ 0.000000] Linux version 5.15.0-91-generic (buildd@lcy02-amd64-045) (gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #101-Ubuntu SMP Tue Nov 14 13:30:08 UTC 2023 (Ubuntu 5.15.0-91.101-generic 5.15.131)
[ 0.000000] Command line: BOOT_IMAGE=/casper/vmlinuz boot=casper username=mint hostname=mint quiet splash –
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000000fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000001000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007a3b1fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007a3b2000-0x000000007a3c1fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007a3c2000-0x000000007a83afff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007a83b000-0x000000007aa42fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007aa43000-0x000000007aa4afff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007aa4b000-0x000000007aa5ffff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000007aa60000-0x000000007aa60fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007aa61000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffbc0000-0x00000000ffbfffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000047effffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: SMBIOS=0x7a946000 SMBIOS 3.0=0x7a944000 ACPI=0x7aa5f000 ACPI 2.0=0x7aa5f014 MEMATTR=0x7783e918 MOKvar=0x7a93f000
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] SMBIOS 3.0.0 present.
[ 0.000000] DMI: Google Chell/Chell, BIOS MrChromebox-4.21.1 10/29/2023
[ 0.000000] tsc: Detected 1500.000 MHz processor
[ 0.000000] tsc: Detected 1499.967 MHz TSC
[ 0.000016] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000024] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000040] last_pfn = 0x47f000 max_arch_pfn = 0x400000000
[ 0.000430] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.002337] last_pfn = 0x7aa61 max_arch_pfn = 0x400000000
[ 0.022377] Using GB pages for direct mapping
[ 0.023471] secureboot: Secure boot disabled
[ 0.023473] RAMDISK: [mem 0x612d0000-0x68aa5fff]
[ 0.023488] ACPI: Early table checksum verification disabled
[ 0.023494] ACPI: RSDP 0x000000007AA5F014 000024 (v02 COREv4)
[ 0.023505] ACPI: XSDT 0x000000007AA5E0E8 000084 (v01 COREv4 COREBOOT 00000000 01000013)
[ 0.023517] ACPI: FACP 0x000000007AA5D000 000114 (v06 COREv4 COREBOOT 00000000 CORE 20230628)
[ 0.023529] ACPI: DSDT 0x000000007AA58000 004612 (v02 COREv4 COREBOOT 20110725 INTL 20230628)
[ 0.023537] ACPI: FACS 0x000000007AA79240 000040
[ 0.023545] ACPI: SSDT 0x000000007AA56000 00170D (v02 COREv4 COREBOOT 00000000 CORE 20230628)
[ 0.023552] ACPI: MCFG 0x000000007AA55000 00003C (v01 COREv4 COREBOOT 00000000 CORE 20230628)
[ 0.023559] ACPI: TCPA 0x000000007AA54000 000032 (v02 COREv4 COREBOOT 00000000 CORE 20230628)
[ 0.023567] ACPI: LPIT 0x000000007AA53000 000094 (v00 COREv4 COREBOOT 00000000 CORE 20230628)
[ 0.023574] ACPI: APIC 0x000000007AA52000 000072 (v03 COREv4 COREBOOT 00000000 CORE 20230628)
[ 0.023581] ACPI: NHLT 0x000000007AA50000 001A50 (v05 COREv4 COREBOOT 00000000 CORE 00000000)
[ 0.023588] ACPI: DMAR 0x000000007AA4F000 000088 (v01 COREv4 COREBOOT 00000000 CORE 20230628)
[ 0.023596] ACPI: DBG2 0x000000007AA4E000 000061 (v00 COREv4 COREBOOT 00000000 CORE 20230628)
[ 0.023603] ACPI: HPET 0x000000007AA4D000 000038 (v01 COREv4 COREBOOT 00000000 CORE 20230628)
[ 0.023610] ACPI: TCPA 0x000000007AA4C000 000032 (v02 INTEL EDK2 00000002 01000013)
[ 0.023618] ACPI: BGRT 0x000000007AA4B000 000038 (v01 INTEL EDK2 00000002 01000013)
[ 0.023624] ACPI: Reserving FACP table memory at [mem 0x7aa5d000-0x7aa5d113]
[ 0.023628] ACPI: Reserving DSDT table memory at [mem 0x7aa58000-0x7aa5c611]
[ 0.023631] ACPI: Reserving FACS table memory at [mem 0x7aa79240-0x7aa7927f]
[ 0.023633] ACPI: Reserving SSDT table memory at [mem 0x7aa56000-0x7aa5770c]
[ 0.023636] ACPI: Reserving MCFG table memory at [mem 0x7aa55000-0x7aa5503b]
[ 0.023638] ACPI: Reserving TCPA table memory at [mem 0x7aa54000-0x7aa54031]
[ 0.023640] ACPI: Reserving LPIT table memory at [mem 0x7aa53000-0x7aa53093]
[ 0.023642] ACPI: Reserving APIC table memory at [mem 0x7aa52000-0x7aa52071]
[ 0.023645] ACPI: Reserving NHLT table memory at [mem 0x7aa50000-0x7aa51a4f]
[ 0.023647] ACPI: Reserving DMAR table memory at [mem 0x7aa4f000-0x7aa4f087]
[ 0.023649] ACPI: Reserving DBG2 table memory at [mem 0x7aa4e000-0x7aa4e060]
[ 0.023652] ACPI: Reserving HPET table memory at [mem 0x7aa4d000-0x7aa4d037]
[ 0.023654] ACPI: Reserving TCPA table memory at [mem 0x7aa4c000-0x7aa4c031]
[ 0.023656] ACPI: Reserving BGRT table memory at [mem 0x7aa4b000-0x7aa4b037]
[ 0.024377] No NUMA configuration found
[ 0.024379] Faking a node at [mem 0x0000000000000000-0x000000047effffff]
[ 0.024404] NODE_DATA(0) allocated [mem 0x47efd6000-0x47effffff]
[ 0.025290] Zone ranges:
[ 0.025292] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.025297] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.025301] Normal [mem 0x0000000100000000-0x000000047effffff]
[ 0.025305] Device empty
[ 0.025308] Movable zone start for each node
[ 0.025314] Early memory node ranges
[ 0.025315] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.025319] node 0: [mem 0x0000000000100000-0x000000007a3b1fff]
[ 0.025322] node 0: [mem 0x000000007a3c2000-0x000000007a83afff]
[ 0.025325] node 0: [mem 0x000000007aa43000-0x000000007aa4afff]
[ 0.025327] node 0: [mem 0x000000007aa60000-0x000000007aa60fff]
[ 0.025329] node 0: [mem 0x0000000100000000-0x000000047effffff]
[ 0.025335] Initmem setup node 0 [mem 0x0000000000001000-0x000000047effffff]
[ 0.025345] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.025415] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.033491] On node 0, zone DMA32: 16 pages in unavailable ranges
[ 0.033510] On node 0, zone DMA32: 520 pages in unavailable ranges
[ 0.033513] On node 0, zone DMA32: 21 pages in unavailable ranges
[ 0.093624] On node 0, zone Normal: 21919 pages in unavailable ranges
[ 0.093751] On node 0, zone Normal: 4096 pages in unavailable ranges
[ 0.093772] Reserving Intel graphics memory at [mem 0x7c000000-0x7fffffff]
[ 0.094009] ACPI: PM-Timer IO Port: 0x1808
[ 0.094024] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.094061] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.094067] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
[ 0.094072] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.094080] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.094083] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.094100] e820: update [mem 0x777e8000-0x7780cfff] usable ==> reserved
[ 0.094122] TSC deadline timer available
[ 0.094124] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.094152] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.094157] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.094161] PM: hibernation: Registered nosave memory: [mem 0x777e8000-0x7780cfff]
[ 0.094165] PM: hibernation: Registered nosave memory: [mem 0x7a3b2000-0x7a3c1fff]
[ 0.094169] PM: hibernation: Registered nosave memory: [mem 0x7a83b000-0x7aa42fff]
[ 0.094173] PM: hibernation: Registered nosave memory: [mem 0x7aa4b000-0x7aa5ffff]
[ 0.094177] PM: hibernation: Registered nosave memory: [mem 0x7aa61000-0x7fffffff]
[ 0.094179] PM: hibernation: Registered nosave memory: [mem 0x80000000-0xffbbffff]
[ 0.094181] PM: hibernation: Registered nosave memory: [mem 0xffbc0000-0xffbfffff]
[ 0.094183] PM: hibernation: Registered nosave memory: [mem 0xffc00000-0xffffffff]
[ 0.094186] [mem 0x80000000-0xffbbffff] available for PCI devices
[ 0.094189] Booting paravirtualized kernel on bare hardware
[ 0.094194] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.094208] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[ 0.094497] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u524288
[ 0.094511] pcpu-alloc: s212992 r8192 d28672 u524288 alloc=1*2097152
[ 0.094517] pcpu-alloc: [0] 0 1 2 3
[ 0.094572] Built 1 zonelists, mobility grouping on. Total pages: 4100307
[ 0.094577] Policy zone: Normal
[ 0.094579] Kernel command line: BOOT_IMAGE=/casper/vmlinuz boot=casper username=mint hostname=mint quiet splash –
[ 0.094802] Unknown kernel command line parameters “splash BOOT_IMAGE=/casper/vmlinuz boot=casper username=mint hostname=mint”, will be passed to user space.
[ 0.096398] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.097198] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.097336] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.182041] Memory: 16066816K/16670540K available (16393K kernel code, 4393K rwdata, 10868K rodata, 3356K init, 18716K bss, 603464K reserved, 0K cma-reserved)
[ 0.184147] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.184226] Kernel/User page tables isolation: enabled
[ 0.184335] ftrace: allocating 50637 entries in 198 pages
[ 0.242517] ftrace: allocated 198 pages with 4 groups
[ 0.242865] rcu: Hierarchical RCU implementation.
[ 0.242867] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
[ 0.242871] Rude variant of Tasks RCU enabled.
[ 0.242872] Tracing variant of Tasks RCU enabled.
[ 0.242874] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.242876] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.253879] NR_IRQS: 524544, nr_irqs: 1024, preallocated irqs: 16
[ 0.254357] random: crng init done
[ 0.254419] spurious 8259A interrupt: IRQ7.
[ 0.254461] Console: colour dummy device 80x25
[ 0.254488] printk: console [tty0] enabled
[ 0.254525] ACPI: Core revision 20210730
[ 0.254668] hpet: HPET dysfunctional in PC10. Force disabled.
[ 0.254671] APIC: Switch to symmetric I/O mode setup
[ 0.254674] DMAR: Host address width 39
[ 0.254676] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.254689] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 7e3ff0505e
[ 0.254697] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.254705] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.254710] DMAR: RMRR base: 0x0000007b800000 end: 0x0000007fffffff
[ 0.254716] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.254719] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.254721] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.256699] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.256704] x2apic enabled
[ 0.256727] Switched APIC routing to cluster x2apic.
[ 0.260877] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x159f036b177, max_idle_ns: 440795223668 ns
[ 0.260891] Calibrating delay loop (skipped), value calculated using timer frequency… 2999.93 BogoMIPS (lpj=5999868)
[ 0.260936] x86/cpu: SGX disabled by BIOS.
[ 0.260952] CPU0: Thermal monitoring enabled (TM1)
[ 0.261059] process: using mwait in idle threads
[ 0.261063] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.261066] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.261076] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.261081] Spectre V2 : Mitigation: IBRS
[ 0.261083] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.261085] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.261087] RETBleed: Mitigation: IBRS
[ 0.261090] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.261093] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.261096] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.261111] MDS: Mitigation: Clear CPU buffers
[ 0.261113] TAA: Mitigation: TSX disabled
[ 0.261115] MMIO Stale Data: Mitigation: Clear CPU buffers
[ 0.261123] SRBDS: Mitigation: Microcode
[ 0.261145] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
[ 0.261149] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
[ 0.261152] x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
[ 0.261154] x86/fpu: Supporting XSAVE feature 0x008: ‘MPX bounds registers’
[ 0.261157] x86/fpu: Supporting XSAVE feature 0x010: ‘MPX CSR’
[ 0.261163] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.261168] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.261172] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.261175] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using ‘compacted’ format.
[ 0.264885] Freeing SMP alternatives memory: 44K
[ 0.264885] pid_max: default: 32768 minimum: 301
[ 0.264885] LSM: Security Framework initializing
[ 0.264885] landlock: Up and running.
[ 0.264885] Yama: becoming mindful.
[ 0.264885] AppArmor: AppArmor initialized
[ 0.264885] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.264885] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.264885] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1979
[ 0.264885] smpboot: CPU0: Intel(R) Core™ m7-6Y75 CPU @ 1.20GHz (family: 0x6, model: 0x4e, stepping: 0x3)
[ 0.264885] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.264885] … version: 4
[ 0.264885] … bit width: 48
[ 0.264885] … generic registers: 4
[ 0.264885] … value mask: 0000ffffffffffff
[ 0.264885] … max period: 00007fffffffffff
[ 0.264885] … fixed-purpose events: 3
[ 0.264885] … event mask: 000000070000000f
[ 0.264885] signal: max sigframe size: 2032
[ 0.264885] rcu: Hierarchical SRCU implementation.
[ 0.264885] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.264885] smp: Bringing up secondary CPUs …
[ 0.264885] x86: Booting SMP configuration:
[ 0.264885] … node #0, CPUs: #1 #2
[ 0.274729] MDS CPU bug present and SMT on, data leak possible. See MDS - Microarchitectural Data Sampling — The Linux Kernel documentation for more details.
[ 0.274729] MMIO Stale Data CPU bug present and SMT on, data leak possible. See Processor MMIO Stale Data Vulnerabilities — The Linux Kernel documentation for more details.
[ 0.274729] #3
[ 0.279335] smp: Brought up 1 node, 4 CPUs
[ 0.279335] smpboot: Max logical packages: 1
[ 0.279335] smpboot: Total of 4 processors activated (11999.73 BogoMIPS)
[ 0.281933] devtmpfs: initialized
[ 0.281933] x86/mm: Memory block size: 128MB
[ 0.285265] ACPI: PM: Registering ACPI NVS region [mem 0x7a3b2000-0x7a3c1fff] (65536 bytes)
[ 0.285265] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.285265] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.285265] pinctrl core: initialized pinctrl subsystem
[ 0.285495] PM: RTC time: 06:30:32, date: 2023-10-29
[ 0.285782] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.286307] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.286578] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.286846] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.286869] audit: initializing netlink subsys (disabled)
[ 0.286893] audit: type=2000 audit(1698561032.024:1): state=initialized audit_enabled=0 res=1
[ 0.286893] thermal_sys: Registered thermal governor ‘fair_share’
[ 0.286893] thermal_sys: Registered thermal governor ‘bang_bang’
[ 0.286893] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.286893] thermal_sys: Registered thermal governor ‘user_space’
[ 0.286893] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.286893] EISA bus registered
[ 0.286893] cpuidle: using governor ladder
[ 0.286893] cpuidle: using governor menu
[ 0.286893] ACPI: bus type PCI registered
[ 0.286893] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.286893] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.286893] PCI: not using MMCONFIG
[ 0.286893] PCI: Using configuration type 1 for base access
[ 0.291829] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.291829] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.291829] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.293053] fbcon: Taking over console
[ 0.293084] ACPI: Added _OSI(Module Device)
[ 0.293086] ACPI: Added _OSI(Processor Device)
[ 0.293089] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.293092] ACPI: Added OSI(Processor Aggregator Device)
[ 0.293094] ACPI: Added OSI(Linux-Dell-Video)
[ 0.293101] ACPI: Added OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.293104] ACPI: Added OSI(Linux-HPI-Hybrid-Graphics)
[ 0.306004] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.309269] ACPI: EC: EC started
[ 0.309272] ACPI: EC: interrupt blocked
[ 0.310435] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.310441] ACPI: _SB
.PCI0.LPCB.EC0
: Boot DSDT EC used to handle transactions
[ 0.310445] ACPI: Interpreter enabled
[ 0.310474] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.310477] ACPI: Using IOAPIC for interrupt routing
[ 0.310525] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.311068] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.311108] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
[ 0.311111] PCI: Using E820 reservations for host bridge windows
[ 0.326577] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.326592] acpi PNP0A08:00: OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.326720] acpi PNP0A08:00: OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.327977] PCI host bridge to bus 0000:00
[ 0.327986] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.327991] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.327996] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.328000] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000fffff window]
[ 0.328004] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 0.328008] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.328012] pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed44fff window]
[ 0.328015] pci_bus 0000:00: root bus resource [mem 0x47f000000-0x7fffffffff window]
[ 0.328373] pci 0000:00:00.0: [8086:190c] type 00 class 0x060000
[ 0.328923] pci 0000:00:02.0: [8086:191e] type 00 class 0x030000
[ 0.328945] pci 0000:00:02.0: reg 0x10: [mem 0x90000000-0x90ffffff 64bit]
[ 0.328962] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref]
[ 0.328973] pci 0000:00:02.0: reg 0x20: [io 0x1000-0x103f]
[ 0.329007] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.329014] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.329550] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[ 0.329574] pci 0000:00:04.0: reg 0x10: [mem 0x91120000-0x91127fff 64bit]
[ 0.330173] pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330
[ 0.330206] pci 0000:00:14.0: reg 0x10: [mem 0x91100000-0x9110ffff 64bit]
[ 0.330315] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.330658] pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000
[ 0.330691] pci 0000:00:14.2: reg 0x10: [mem 0x91130000-0x91130fff 64bit]
[ 0.331392] pci 0000:00:15.0: [8086:9d60] type 00 class 0x118000
[ 0.331433] pci 0000:00:15.0: reg 0x10: [mem 0x91131000-0x91131fff 64bit]
[ 0.332045] pci 0000:00:15.1: [8086:9d61] type 00 class 0x118000
[ 0.332086] pci 0000:00:15.1: reg 0x10: [mem 0x91132000-0x91132fff 64bit]
[ 0.332735] pci 0000:00:19.0: [8086:9d66] type 00 class 0x118000
[ 0.332777] pci 0000:00:19.0: reg 0x10: [mem 0xfe030000-0xfe030fff 64bit]
[ 0.332804] pci 0000:00:19.0: reg 0x18: [mem 0x91134000-0x91134fff 64bit]
[ 0.333403] pci 0000:00:19.2: [8086:9d64] type 00 class 0x118000
[ 0.333445] pci 0000:00:19.2: reg 0x10: [mem 0x91135000-0x91135fff 64bit]
[ 0.334083] pci 0000:00:1c.0: [8086:9d10] type 01 class 0x060400
[ 0.334228] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.334801] pci 0000:00:1e.0: [8086:9d27] type 00 class 0x118000
[ 0.334843] pci 0000:00:1e.0: reg 0x10: [mem 0x91136000-0x91136fff 64bit]
[ 0.335465] pci 0000:00:1e.4: [8086:9d2b] type 00 class 0x080501
[ 0.335504] pci 0000:00:1e.4: reg 0x10: [mem 0x91137000-0x91137fff 64bit]
[ 0.336426] pci 0000:00:1f.0: [8086:9d46] type 00 class 0x060100
[ 0.337061] pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000
[ 0.337090] pci 0000:00:1f.2: reg 0x10: [mem 0x91128000-0x9112bfff]
[ 0.337656] pci 0000:00:1f.3: [8086:9d70] type 00 class 0x040100
[ 0.337695] pci 0000:00:1f.3: reg 0x10: [mem 0x9112c000-0x9112ffff 64bit]
[ 0.337745] pci 0000:00:1f.3: reg 0x20: [mem 0x91110000-0x9111ffff 64bit]
[ 0.337824] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.338530] pci 0000:00:1f.4: [8086:9d23] type 00 class 0x0c0500
[ 0.338598] pci 0000:00:1f.4: reg 0x10: [mem 0x91139000-0x911390ff 64bit]
[ 0.338677] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.339064] pci 0000:00:1f.5: [8086:9d24] type 00 class 0x000000
[ 0.339094] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.339609] pci 0000:01:00.0: [8086:095a] type 00 class 0x028000
[ 0.339673] pci 0000:01:00.0: reg 0x10: [mem 0x91000000-0x91001fff 64bit]
[ 0.339962] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.340669] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.340686] pci 0000:00:1c.0: bridge window [mem 0x91000000-0x910fffff]
[ 0.341635] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[ 0.341819] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[ 0.341998] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
[ 0.342176] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
[ 0.342354] ACPI: PCI: Interrupt link LNKE configured for IRQ 11
[ 0.342531] ACPI: PCI: Interrupt link LNKF configured for IRQ 11
[ 0.342709] ACPI: PCI: Interrupt link LNKG configured for IRQ 11
[ 0.342886] ACPI: PCI: Interrupt link LNKH configured for IRQ 11
[ 0.345843] ACPI: EC: interrupt unblocked
[ 0.345846] ACPI: EC: event unblocked
[ 0.345863] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.345866] ACPI: EC: GPE=0x50
[ 0.345870] ACPI: _SB
.PCI0.LPCB.EC0
: Boot DSDT EC initialization complete
[ 0.345875] ACPI: _SB
.PCI0.LPCB.EC0
: EC: Used to handle transactions and events
[ 0.346018] iommu: Default domain type: Translated
[ 0.346018] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.346018] SCSI subsystem initialized
[ 0.346018] libata version 3.00 loaded.
[ 0.346018] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.346018] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.346018] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.346018] vgaarb: loaded
[ 0.346018] ACPI: bus type USB registered
[ 0.346018] usbcore: registered new interface driver usbfs
[ 0.346018] usbcore: registered new interface driver hub
[ 0.346018] usbcore: registered new device driver usb
[ 0.346018] pps_core: LinuxPPS API ver. 1 registered
[ 0.346018] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.346018] PTP clock support registered
[ 0.346018] EDAC MC: Ver: 3.0.0
[ 0.346018] Registered efivars operations
[ 0.346018] NetLabel: Initializing
[ 0.346018] NetLabel: domain hash size = 128
[ 0.346018] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.346018] NetLabel: unlabeled traffic allowed by default
[ 0.346018] PCI: Using ACPI for IRQ routing
[ 0.376800] PCI: pci_cache_line_size set to 64 bytes
[ 0.376904] e820: reserve RAM buffer [mem 0x777e8000-0x77ffffff]
[ 0.376909] e820: reserve RAM buffer [mem 0x7a3b2000-0x7bffffff]
[ 0.376912] e820: reserve RAM buffer [mem 0x7a83b000-0x7bffffff]
[ 0.376915] e820: reserve RAM buffer [mem 0x7aa4b000-0x7bffffff]
[ 0.376918] e820: reserve RAM buffer [mem 0x7aa61000-0x7bffffff]
[ 0.376920] e820: reserve RAM buffer [mem 0x47f000000-0x47fffffff]
[ 0.380245] clocksource: Switched to clocksource tsc-early
[ 0.400820] VFS: Disk quotas dquot_6.6.0
[ 0.400861] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.401190] AppArmor: AppArmor Filesystem Enabled
[ 0.401245] pnp: PnP ACPI init
[ 0.401400] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.401887] system 00:01: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.401896] system 00:01: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.401903] system 00:01: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.401911] system 00:01: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.401918] system 00:01: [mem 0xff000000-0xffffffff] could not be reserved
[ 0.401925] system 00:01: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.401931] system 00:01: [mem 0xfed00000-0xfed003ff] has been reserved
[ 0.402564] system 00:02: [mem 0xfed00000-0xfed003ff] has been reserved
[ 0.402710] system 00:03: [io 0x1800-0x18fe] has been reserved
[ 0.403434] system 00:05: [io 0x0900-0x09fe] has been reserved
[ 0.403566] system 00:06: [io 0x0200] has been reserved
[ 0.403573] system 00:06: [io 0x0204] has been reserved
[ 0.403579] system 00:06: [io 0x0800-0x087f] has been reserved
[ 0.403585] system 00:06: [io 0x0880-0x08ff] has been reserved
[ 0.404493] pnp: PnP ACPI: found 9 devices
[ 0.412739] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.412969] NET: Registered PF_INET protocol family
Two posts because of character limit:
Summary
[ 0.413272] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.418436] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.418502] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.418662] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.419018] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.419166] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.419315] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.419486] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.419584] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.419705] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.419716] NET: Registered PF_XDP protocol family
[ 0.419737] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.419755] pci 0000:00:1c.0: bridge window [mem 0x91000000-0x910fffff]
[ 0.419777] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.419782] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.419786] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000fffff window]
[ 0.419790] pci_bus 0000:00: resource 7 [mem 0x80000000-0xdfffffff window]
[ 0.419794] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[ 0.419797] pci_bus 0000:00: resource 9 [mem 0xfed40000-0xfed44fff window]
[ 0.419801] pci_bus 0000:00: resource 10 [mem 0x47f000000-0x7fffffffff window]
[ 0.419806] pci_bus 0000:01: resource 1 [mem 0x91000000-0x910fffff]
[ 0.420633] PCI: CLS 64 bytes, default 64
[ 0.420699] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.420702] software IO TLB: mapped [mem 0x00000000737ab000-0x00000000777ab000] (64MB)
[ 0.420755] Trying to unpack rootfs image as initramfs…
[ 0.428191] Initialise system trusted keyrings
[ 0.428212] Key type blacklist registered
[ 0.428282] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[ 0.433162] zbud: loaded
[ 0.434033] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.434419] fuse: init (API version 7.34)
[ 0.434816] integrity: Platform Keyring initialized
[ 0.453610] Key type asymmetric registered
[ 0.453616] Asymmetric key parser ‘x509’ registered
[ 0.453663] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.453735] io scheduler mq-deadline registered
[ 0.454641] pcieport 0000:00:1c.0: PME: Signaling with IRQ 122
[ 0.454892] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.456857] ACPI: AC: AC Adapter [AC] (off-line)
[ 0.457015] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:06/PNP0C09:00/PNP0C0D:00/input/input0
[ 0.457107] ACPI: button: Lid Switch [LID0]
[ 0.457225] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.457298] ACPI: button: Power Button [PWRF]
[ 0.458451] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.462813] hpet_acpi_add: no address or irqs in _CRS
[ 0.462897] Linux agpgart interface v0.103
[ 0.465225] tpm_tis 00:08: 1.2 TPM (device-id 0x1B, rev-id 16)
[ 0.475727] ACPI: battery: Slot [BAT0] (battery present)
[ 0.542891] loop: module loaded
[ 0.543496] tun: Universal TUN/TAP device driver, 1.6
[ 0.543566] PPP generic driver version 2.4.2
[ 0.543682] VFIO - User Level meta-driver version: 0.3
[ 0.543828] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.543836] ehci-pci: EHCI PCI platform driver
[ 0.543854] ehci-platform: EHCI generic platform driver
[ 0.543872] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.543876] ohci-pci: OHCI PCI platform driver
[ 0.543894] ohci-platform: OHCI generic platform driver
[ 0.543908] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.544010] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 0.544016] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.547208] i8042: Warning: Keylock active
[ 0.547425] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.547615] mousedev: PS/2 mouse device common for all mice
[ 0.547844] rtc_cmos 00:04: RTC can wake from S4
[ 0.548600] rtc_cmos 00:04: registered as rtc0
[ 0.548741] rtc_cmos 00:04: setting system clock to 2023-10-29T06:30:32 UTC (1698561032)
[ 0.548795] rtc_cmos 00:04: alarms up to one month, y3k, 242 bytes nvram
[ 0.548812] i2c_dev: i2c /dev entries driver
[ 0.549453] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[ 0.549510] device-mapper: uevent: version 1.0.3
[ 0.549621] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: [email protected]
[ 0.549665] platform eisa.0: Probing EISA bus 0
[ 0.549670] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 0.549673] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 0.549677] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 0.549680] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 0.549682] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 0.549685] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 0.549688] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 0.549691] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 0.549694] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 0.549697] platform eisa.0: EISA: Detected 0 cards
[ 0.549703] intel_pstate: Intel P-state driver initializing
[ 0.549968] intel_pstate: HWP enabled
[ 0.550071] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.550107] efifb: probing for efifb
[ 0.550148] efifb: showing boot graphics
[ 0.551326] efifb: framebuffer at 0x80000000, using 8100k, total 8100k
[ 0.551328] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 0.551330] efifb: scrolling: redraw
[ 0.551331] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.551459] Console: switching to colour frame buffer device 240x67
[ 0.556358] fb0: EFI VGA frame buffer device
[ 0.556395] EFI Variables Facility v0.08 2004-May-17
[ 0.557298] intel_pmc_core INT33A1:00: initialized
[ 0.557416] drop_monitor: Initializing network drop monitor service
[ 0.557672] NET: Registered PF_INET6 protocol family
[ 0.558066] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 1.208166] Freeing initrd memory: 122712K
[ 1.216600] Segment Routing with IPv6
[ 1.216614] In-situ OAM (IOAM) with IPv6
[ 1.216645] NET: Registered PF_PACKET protocol family
[ 1.216729] Key type dns_resolver registered
[ 1.217101] microcode: sig=0x406e3, pf=0x80, revision=0xf0
[ 1.217119] microcode: Microcode Update Driver: v2.2.
[ 1.217125] IPI shorthand broadcast: enabled
[ 1.217157] sched_clock: Marking stable (1210435422, 6583231)->(1298589366, -81570713)
[ 1.217395] registered taskstats version 1
[ 1.217507] Loading compiled-in X.509 certificates
[ 1.218117] Loaded X.509 cert ‘Build time autogenerated kernel key: 5d922c8510ab93d63cb90d7e9088ad693f9da42f’
[ 1.218654] Loaded X.509 cert ‘Canonical Ltd. Live Patch Signing: 14df34d1a87cf37625abec039ef2bf521249b969’
[ 1.219176] Loaded X.509 cert ‘Canonical Ltd. Kernel Module Signing: 88f752e560a1e0737e31163a466ad7b70a850c19’
[ 1.219177] blacklist: Loading compiled-in revocation X.509 certificates
[ 1.219196] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing: 61482aa2830d0ab2ad5af10b7250da9033ddcef0’
[ 1.219211] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing (2017): 242ade75ac4a15e50d50c84b0d45ff3eae707a03’
[ 1.219225] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing (ESM 2018): 365188c1d374d6b07c3c8f240f8ef722433d6a8b’
[ 1.219239] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing (2019): c0746fd6c5da3ae827864651ad66ae47fe24b3e8’
[ 1.219257] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing (2021 v1): a8d54bbb3825cfb94fa13c9f8a594a195c107b8d’
[ 1.219271] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing (2021 v2): 4cf046892d6fd3c9a5b03f98d845f90851dc6a8c’
[ 1.219284] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing (2021 v3): 100437bb6de6e469b581e61cd66bce3ef4ed53af’
[ 1.219298] Loaded X.509 cert ‘Canonical Ltd. Secure Boot Signing (Ubuntu Core 2019): c1d57b8f6b743f23ee41f4f7ee292f06eecadfb9’
[ 1.219394] zswap: loaded using pool lzo/zbud
[ 1.219542] Key type .fscrypt registered
[ 1.219543] Key type fscrypt-provisioning registered
[ 1.219642] Key type trusted registered
[ 1.223503] Key type encrypted registered
[ 1.223508] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.223894] integrity: Loading X.509 certificate: UEFI:db
[ 1.223923] integrity: Loaded X.509 cert ‘Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53’
[ 1.223924] integrity: Loading X.509 certificate: UEFI:db
[ 1.223944] integrity: Loaded X.509 cert ‘Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4’
[ 1.224460] integrity: Loading X.509 certificate: UEFI:MokListRT (MOKvar table)
[ 1.224982] integrity: Loaded X.509 cert ‘Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63’
[ 1.224988] Loading compiled-in module X.509 certificates
[ 1.225519] Loaded X.509 cert ‘Build time autogenerated kernel key: 5d922c8510ab93d63cb90d7e9088ad693f9da42f’
[ 1.225521] ima: Allocated hash algorithm: sha1
[ 1.259908] ima: No architecture policies found
[ 1.259931] evm: Initialising EVM extended attributes:
[ 1.259932] evm: security.selinux
[ 1.259934] evm: security.SMACK64
[ 1.259936] evm: security.SMACK64EXEC
[ 1.259937] evm: security.SMACK64TRANSMUTE
[ 1.259938] evm: security.SMACK64MMAP
[ 1.259939] evm: security.apparmor
[ 1.259940] evm: security.ima
[ 1.259941] evm: security.capability
[ 1.259943] evm: HMAC attrs: 0x1
[ 1.260373] PM: Magic number: 11:317:520
[ 1.260854] RAS: Correctable Errors collector initialized.
[ 1.262654] Freeing unused decrypted memory: 2036K
[ 1.263439] Freeing unused kernel image (initmem) memory: 3356K
[ 1.294833] Write protecting the kernel read-only data: 30720k
[ 1.296396] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 1.297166] Freeing unused kernel image (rodata/data gap) memory: 1420K
[ 1.372061] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.372063] x86/mm: Checking user space page tables
[ 1.420989] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.420994] Run /init as init process
[ 1.420996] with arguments:
[ 1.420997] /init
[ 1.420998] splash
[ 1.420999] with environment:
[ 1.421000] HOME=/
[ 1.421001] TERM=linux
[ 1.421001] BOOT_IMAGE=/casper/vmlinuz
[ 1.421002] boot=casper
[ 1.421003] username=mint
[ 1.421004] hostname=mint
[ 1.442636] tsc: Refined TSC clocksource calibration: 1511.997 MHz
[ 1.442657] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x15cb67c42b6, max_idle_ns: 440795205343 ns
[ 1.442677] clocksource: Switched to clocksource tsc
[ 1.557492] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.557503] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.558774] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
[ 1.559057] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 1.559777] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.559785] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.559791] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 1.559846] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.559849] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.559852] usb usb1: Product: xHCI Host Controller
[ 1.559854] usb usb1: Manufacturer: Linux 5.15.0-91-generic xhci-hcd
[ 1.559856] usb usb1: SerialNumber: 0000:00:14.0
[ 1.562669] hub 1-0:1.0: USB hub found
[ 1.562698] hub 1-0:1.0: 12 ports detected
[ 1.564775] sdhci: Secure Digital Host Controller Interface driver
[ 1.564776] sdhci: Copyright(c) Pierre Ossman
[ 1.568151] sdhci-pci 0000:00:1e.4: SDHCI controller found [8086:9d2b] (rev 21)
[ 1.570354] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 1.570398] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 1.570707] mmc0: SDHCI controller on PCI [0000:00:1e.4] using ADMA 64-bit
[ 1.570956] cros_ec_lpcs GOOG0004:00: Chrome EC device registered
[ 1.571937] i2c i2c-0: 2/2 memory slots populated (from DMI)
[ 1.577285] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 1.577317] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.577322] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.577325] usb usb2: Product: xHCI Host Controller
[ 1.577326] usb usb2: Manufacturer: Linux 5.15.0-91-generic xhci-hcd
[ 1.577328] usb usb2: SerialNumber: 0000:00:14.0
[ 1.577887] hub 2-0:1.0: USB hub found
[ 1.577908] hub 2-0:1.0: 6 ports detected
[ 1.588762] idma64 idma64.4: Found Intel integrated DMA 64-bit
[ 1.606067] cryptd: max_cpu_qlen set to 1000
[ 1.611914] AVX2 version of gcm_enc/dec engaged.
[ 1.611955] AES CTR mode by8 optimization enabled
[ 1.695357] Console: switching to colour dummy device 80x25
[ 1.695431] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 1.747477] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 1.748466] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/skl_dmc_ver1_27.bin (v1.27)
[ 1.914733] usb 1-3: new full-speed USB device number 2 using xhci_hcd
[ 2.064527] usb 1-3: New USB device found, idVendor=8087, idProduct=0a2a, bcdDevice= 0.03
[ 2.064541] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.191103] usb 2-3: new SuperSpeed USB device number 2 using xhci_hcd
[ 2.213721] usb 2-3: New USB device found, idVendor=05dc, idProduct=a833, bcdDevice=11.00
[ 2.213738] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.213746] usb 2-3: Product: USB Flash Drive
[ 2.213752] usb 2-3: Manufacturer: Lexar
[ 2.213758] usb 2-3: SerialNumber: AAWAQMS4VD5BKE2K
[ 2.226826] usb-storage 2-3:1.0: USB Mass Storage device detected
[ 2.227258] scsi host0: usb-storage 2-3:1.0
[ 2.227570] usbcore: registered new interface driver usb-storage
[ 2.231725] usbcore: registered new interface driver uas
[ 2.338885] usb 1-7: new high-speed USB device number 3 using xhci_hcd
[ 2.541650] usb 1-7: New USB device found, idVendor=0408, idProduct=5060, bcdDevice= 0.06
[ 2.541670] usb 1-7: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2.541679] usb 1-7: Product: HP Truevision HD
[ 2.541686] usb 1-7: Manufacturer: Generic
[ 2.541692] usb 1-7: SerialNumber: 200901010001
[ 2.858055] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ 2.859359] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 2.860153] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3
[ 3.096299] fbcon: i915drmfb (fb0) is primary device
[ 3.096706] i915 0000:00:02.0: [drm] Reducing the compressed framebuffer size. This may lead to less power savings than a non-reduced-size. Try to increase stolen memory size if available in BIOS.
[ 3.104062] Console: switching to colour frame buffer device 200x56
[ 3.152524] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 3.330001] scsi 0:0:0:0: Direct-Access Lexar USB Flash Drive 1100 PQ: 0 ANSI: 6
[ 3.331019] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3.332103] sd 0:0:0:0: [sda] 31285248 512-byte logical blocks: (16.0 GB/14.9 GiB)
[ 3.333186] sd 0:0:0:0: [sda] Write Protect is off
[ 3.333198] sd 0:0:0:0: [sda] Mode Sense: 22 00 00 00
[ 3.333813] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 3.339572] sda: sda1 sda2
[ 3.344109] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 4.197347] loop0: detected capacity change from 0 to 4912456
[ 4.273304] overlayfs: null uuid detected in lower fs ‘/’, falling back to xino=off,index=off,nfs_export=off.
[ 11.144850] systemd[1]: Inserted module ‘autofs4’
[ 11.209910] systemd[1]: systemd 249.11-0ubuntu3.11 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 11.226891] systemd[1]: Detected architecture x86-64.
[ 11.239400] systemd[1]: Initializing machine ID from random generator.
[ 11.732417] systemd[1]: Queued start job for default target Graphical Interface.
[ 11.733847] systemd[1]: Created slice Slice /system/modprobe.
[ 11.734311] systemd[1]: Created slice User and Session Slice.
[ 11.734422] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.734656] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 11.734704] systemd[1]: Reached target User and Group Name Lookups.
[ 11.734720] systemd[1]: Reached target Remote File Systems.
[ 11.734737] systemd[1]: Reached target Slice Units.
[ 11.734756] systemd[1]: Reached target Swaps.
[ 11.734775] systemd[1]: Reached target Local Verity Protected Volumes.
[ 11.734868] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 11.736118] systemd[1]: Listening on LVM2 poll daemon socket.
[ 11.736631] systemd[1]: Listening on Syslog Socket.
[ 11.739051] systemd[1]: Listening on Process Core Dump Socket.
[ 11.739119] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 11.739397] systemd[1]: Listening on Journal Audit Socket.
[ 11.739517] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.739676] systemd[1]: Listening on Journal Socket.
[ 11.741426] systemd[1]: Listening on udev Control Socket.
[ 11.741561] systemd[1]: Listening on udev Kernel Socket.
[ 11.742548] systemd[1]: Mounting Huge Pages File System…
[ 11.743455] systemd[1]: Mounting POSIX Message Queue File System…
[ 11.744573] systemd[1]: Mounting Kernel Debug File System…
[ 11.745735] systemd[1]: Mounting Kernel Trace File System…
[ 11.748192] systemd[1]: Starting Journal Service…
[ 11.748507] systemd[1]: Finished Availability of block devices.
[ 11.750065] systemd[1]: Starting Set the console keyboard layout…
[ 11.753377] systemd[1]: Starting Create List of Static Device Nodes…
[ 11.754906] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 11.756244] systemd[1]: Starting Load Kernel Module configfs…
[ 11.757592] systemd[1]: Starting Load Kernel Module drm…
[ 11.758952] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 11.760080] systemd[1]: Starting Load Kernel Module fuse…
[ 11.789388] systemd[1]: Starting Load Kernel Modules…
[ 11.790343] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 11.795098] systemd[1]: Starting Coldplug All udev Devices…
[ 11.803747] systemd[1]: Mounted Huge Pages File System.
[ 11.806415] systemd[1]: Mounted POSIX Message Queue File System.
[ 11.806660] systemd[1]: Mounted Kernel Debug File System.
[ 11.806893] systemd[1]: Mounted Kernel Trace File System.
[ 11.807468] systemd[1]: Finished Create List of Static Device Nodes.
[ 11.808064] systemd[1]: [email protected]: Deactivated successfully.
[ 11.808438] systemd[1]: Finished Load Kernel Module configfs.
[ 11.808863] systemd[1]: [email protected]: Deactivated successfully.
[ 11.809266] systemd[1]: Finished Load Kernel Module drm.
[ 11.809766] systemd[1]: [email protected]: Deactivated successfully.
[ 11.810082] systemd[1]: Finished Load Kernel Module fuse.
[ 11.811460] systemd[1]: Mounting FUSE Control File System…
[ 11.812915] systemd[1]: Mounting Kernel Configuration File System…
[ 11.818748] systemd[1]: Mounted FUSE Control File System.
[ 11.819003] systemd[1]: Mounted Kernel Configuration File System.
[ 11.821586] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 11.824251] systemd[1]: Starting Load/Save Random Seed…
[ 11.828846] pstore: Using crash dump compression: deflate
[ 11.828852] pstore: Registered efi as persistent store backend
[ 11.839190] systemd[1]: Starting Create System Users…
[ 11.839880] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 11.840315] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 11.840567] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 11.840763] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 11.858851] systemd[1]: Started Journal Service.
[ 11.935854] systemd-journald[764]: Received client request to flush runtime journal.
[ 11.988292] lp: driver loaded but no devices found
[ 12.006153] ppdev: user-space parallel port driver
[ 13.346775] elan_i2c i2c-ELAN0000:00: supply vcc not found, using dummy regulator
[ 13.422828] dw-apb-uart.2: ttyS4 at MMIO 0xfe030000 (irq = 32, base_baud = 115200) is a 16550A
[ 13.446880] dw-apb-uart.4: ttyS5 at MMIO 0x91136000 (irq = 20, base_baud = 7500000) is a 16550A
[ 13.466447] elan_i2c i2c-ELAN0000:00: Elan Touchpad: Module ID: 0x007b, Firmware: 0x0002, Sample: 0x0005, IAP: 0x000d
[ 13.468069] input: Elan Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-ELAN0000:00/input/input4
[ 13.534348] cros-ec-pchg cros-ec-pchg.8.auto: Unable to get number or ports (err:-95)
[ 13.534354] cros-ec-pchg cros-ec-pchg.8.auto: No peripheral charge ports (err:-95)
[ 13.549191] cros-ec-pchg cros-ec-pchg.12.auto: Unable to get number or ports (err:-95)
[ 13.549197] cros-ec-pchg cros-ec-pchg.12.auto: No peripheral charge ports (err:-95)
[ 13.550538] cros-usbpd-charger cros-usbpd-charger.3.auto: Could not get charger port count
[ 13.744860] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 13.744865] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 13.744867] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 13.744869] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 13.744871] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 13.744873] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 13.971282] intel_rapl_common: Found RAPL domain package
[ 13.971287] intel_rapl_common: Found RAPL domain dram
[ 14.517023] intel_rapl_common: Found RAPL domain package
[ 14.517030] intel_rapl_common: Found RAPL domain core
[ 14.517033] intel_rapl_common: Found RAPL domain uncore
[ 14.517038] intel_rapl_common: Found RAPL domain dram
[ 14.517042] intel_rapl_common: Found RAPL domain psys
[ 16.892922] mc: Linux media interface: v0.10
[ 18.438949] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 19.425175] videodev: Linux video capture interface: v2.00
[ 19.984059] nau8825 i2c-10508825:00: No ‘mclk’ clock found, assume MCLK is managed externally
[ 20.397728] usb 1-7: Found UVC 1.00 device HP Truevision HD (0408:5060)
[ 20.409640] input: HP Truevision HD: HP Truevision as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/input/input5
[ 20.409726] usbcore: registered new interface driver uvcvideo
[ 20.752130] Bluetooth: Core ver 2.22
[ 20.752160] NET: Registered PF_BLUETOOTH protocol family
[ 20.752162] Bluetooth: HCI device and connection manager initialized
[ 20.752169] Bluetooth: HCI socket layer initialized
[ 20.752172] Bluetooth: L2CAP socket layer initialized
[ 20.752177] Bluetooth: SCO socket layer initialized
[ 20.922990] usbcore: registered new interface driver btusb
[ 20.932593] Bluetooth: hci0: Legacy ROM 2.x revision 5.0 build 25 week 20 2015
[ 20.986234] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq
[ 21.158975] snd_soc_skl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 21.159842] snd_soc_skl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 21.198540] HDMI HDA Codec ehdaudio0D2: Max dais supported: 3
[ 21.212797] snd_soc_skl 0000:00:1f.3: Direct firmware load for 9d70-COREv4-COREBOOT-0-tplg.bin failed with error -2
[ 21.212804] snd_soc_skl 0000:00:1f.3: tplg fw 9d70-COREv4-COREBOOT-0-tplg.bin load failed with -2, trying alternative tplg name skl_n88l25_s4567-tplg.bin
[ 21.216209] snd_soc_skl 0000:00:1f.3: Direct firmware load for skl_n88l25_s4567-tplg.bin failed with error -2
[ 21.216215] snd_soc_skl 0000:00:1f.3: tplg skl_n88l25_s4567-tplg.bin failed with -2, falling back to dfw_sst.bin
[ 21.216321] snd_soc_skl 0000:00:1f.3: Direct firmware load for dfw_sst.bin failed with error -2
[ 21.216325] snd_soc_skl 0000:00:1f.3: Fallback tplg fw dfw_sst.bin load failed with -2
[ 21.216331] snd_soc_skl 0000:00:1f.3: Failed to init topology!
[ 21.216335] snd_soc_skl 0000:00:1f.3: ASoC: error at snd_soc_component_probe on 0000:00:1f.3: -2
[ 21.216372] skl_n88l25_s4567 skl_n88l25_s4567: ASoC: failed to instantiate card -2
[ 21.216571] skl_n88l25_s4567: probe of skl_n88l25_s4567 failed with error -2
[ 21.351651] Bluetooth: hci0: Intel BT fw patch 0x43 completed & activated
[ 21.494251] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 21.494684] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 22.168364] Intel(R) Wireless WiFi driver for Linux
[ 22.195098] intel_tcc_cooling: Programmable TCC Offset detected
[ 22.256360] spl: loading out-of-tree module taints kernel.
[ 22.301304] znvpair: module license ‘CDDL’ taints kernel.
[ 22.301307] Disabling lock debugging due to kernel taint
[ 22.337665] iwlwifi 0000:01:00.0: Found debug destination: EXTERNAL_DRAM
[ 22.337670] iwlwifi 0000:01:00.0: Found debug configuration: 0
[ 22.337878] iwlwifi 0000:01:00.0: loaded firmware version 29.4063824552.0 7265D-29.ucode op_mode iwlmvm
[ 23.436610] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 7265, REV=0x210
[ 23.442913] thermal thermal_zone8: failed to read out thermal zone (-61)
[ 23.449916] iwlwifi 0000:01:00.0: Applying debug destination EXTERNAL_DRAM
[ 23.450417] iwlwifi 0000:01:00.0: Allocated 0x00400000 bytes for firmware monitor.
[ 23.455344] iwlwifi 0000:01:00.0: base HW address: e4:42:a6:72:de:e0
[ 23.522837] ieee80211 phy0: Selected rate control algorithm ‘iwl-mvm-rs’
[ 23.534264] iwlwifi 0000:01:00.0 wlp1s0: renamed from wlan0
[ 23.651818] ZFS: Loaded module v2.1.5-1ubuntu6~22.04.1, ZFS pool version 5000, ZFS filesystem version 5
[ 36.342994] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 36.342998] Bluetooth: BNEP filters: protocol multicast
[ 36.343003] Bluetooth: BNEP socket layer initialized
[ 36.401687] NET: Registered PF_ALG protocol family
[ 50.675526] iwlwifi 0000:01:00.0: Applying debug destination EXTERNAL_DRAM
[ 50.769817] iwlwifi 0000:01:00.0: Applying debug destination EXTERNAL_DRAM
[ 50.771616] iwlwifi 0000:01:00.0: FW already configured (0) - re-configuring
[ 64.554156] Bluetooth: RFCOMM TTY layer initialized
[ 64.554168] Bluetooth: RFCOMM socket layer initialized
[ 64.554174] Bluetooth: RFCOMM ver 1.11
mint@mint:~$
I’m having the same issue, but my chromebook model is C340-15 (Nami).
The eMMC can be recognized in the boot menu before de-soldered the 32GB eMMC, but after replaced it with a 128GB chip. It doesn’t show up in the UEFI boot menu. Running MrChromeBox-4.22.2-5.
The new eMMC chip can be see in WinPE and can be written to Windows files. EFI partitions can be built however it also doesn’t show up in the UEFI boot menu.
Greetings, I also have a device of that model, and I am interested if this storage change can be made.
