CCD cable flashrom Raiden: Failed to enable SPI bridge
Do you know if this device is compatible with the SuzyQ Cable for CCD flashing externally?
Flashrom always fails to read the chips.
I would like to backup the coreboot image and be able to reflash it in cases when the laptop was in strangers hands etc.
$ lsusb
# cr50 is there
$ echo "ccd open" | sudo tee -a /dev/ttyUSB0 > /dev/null
$ sudo flashrom -p raiden_debug_spi:target=AP
flashrom 1.4.0 on Linux 6.11.5-200.fc40.x86_64 (x86_64)
FISK: AP
Raiden target: 2,0
libusb error: ../raiden_debug_spi.c:1601 LIBUSB_ERROR_IO
Error: Programmer initialization failed.
Using Fedora 40 Kinoite
