Sorry if my English is bad.
So i was trying to install pop os on my chromebook via rw legacy seabios
The following things happened
- I press ctrl+l then i have to select an number (select a numeric key to select ab alternative bootloader: )
- When I press any number it loads and then i get to the part with press esc for boot menu which only shows internal storage
And then it shows some other things and then I am stuck
Does anyone know how to fix this?
video link: 82497152-DB73-4FD6-B542-4CE03EDF6289.MP4 - Google Drive
Thanks!
