Cannot flash Full ROM on top of a Legacy ROM
Hello,
I’m a happy Samsung Chromebox 3 (stumpy) owner, it survived 3 home moves and is serving me h24 since about 10 years. I decided to give it an upgrade to a UEFI Full ROM but I’m experiencing some difficulties in doing so.
The device is currently running a legacy SeaBIOS firmware that the Firmware Tool displays as “MrChromebox (11/11/2016)”: @MrChromebox probably won’t remember it, but we were chatting on Google Chat on those days and experimenting with auto-power-on on AC loss, so this was a firmware from those test builds. (unfortunately auto-power-on did not work, by the way, but that’s another story :stuck_out_tongue: ).
I’m currently running an Ubuntu 22.04 on it, I can’t go back to stock firmware since I replaced the SSD with a bigger one and I remember the stock firmware didn’t like this. So, I’m running the Firmware Tool from Ubuntu itself.
However, when I try to “Install/update Full UEFI (Full ROM) Firmware” (option 1), it fails with this error:
Error running cmd: /tmp/flashrom -p internal:boardmismatch=force --ifd -i bios -N -w coreboot_edk2-stumpy-mrchromebox_20240914.rom >/dev/null 2>&1 -o /tmp/flashrom.log
Here is the full content of /tmp/flashrom.log: flashrom MrChromebox-1.4.0-devel_2024.04.18 (git:v1.2-1418-ge5ed0c6340) on Linux - Pastebin.com
Can I please get some help? :slight_smile:
Thank you!
what happens if you use the distro’s built-in flashrom?
sudo flashrom -p internal --ifd -i bios -N -w /tmp/coreboot_edk2-stumpy-mrchromebox_20240914.rom -o /tmp/flashrom.log
you might need to add -c "chipname" if it detects multiple chips. In that case, try with each option (assuming the first doesn’t work)
Seems like this was the way to go, thank you!
On first run it asked me to choose between “W25Q64BV/W25Q64CV/W25Q64FV” and “W25Q64JV-.Q”. I used the first one as “-c” argument and it flashed correctly.
I’ll now verify if everything works.
It it’ useful:
have the full log from that (/tmp/flashrom.log)?
Uh sorry, I already rebooted and I just finished converting my setup to UEFI. I didn’t think of taking the log before rebooting, and it’s gone now.
I tried running it again, but it will tell me that the content is identical: Hastebin
Interesting fact. I tried running it through your script again and it gave no error: Hastebin . Maybe it’s because the content is still identical.
If there is something I can do to make it force flash again, I’ll send the logs.
Thanks again!
Hello again,
I received a notification that two posts into the thread have been hidden because flagged as Spam.
I suspect it’s due to the links to the log files, but I just used Pastebin like everyone does, to avoid making a wall of text into the post itself.
I think that the solution given here by @MrCrhomebox is really precious, and I don’t want it to be hidden! Can I have some feedback by the community, instead of just spam flags (?), on how I’m supposed to post logs?
Thank you
it’s fine, I approved the posts. The spam detection system is just sensitive to new users posting multiple links in a single post it seems.
I’ll be updating the script once I figure out why it failed for you but not for me. I was using Pop_OS! 22.04
Cool, thank you! If I can be of any help with testing it just let me know! Meanwhile I can confirm that the flash succeeded and the system works like a charm :partying_face:
