Can I remove the write protect on Acer 315 Chromebook without disconnecting the battery and using some commands?
If not, then please explain me where is the screw or something that I can remove to disable it, thank you.
the documentation on my site tells you how to identify your device’s board name, and provides info on the WP disablement methods available for each board. Acer 315 is useless as it’s ambiguous - which is why we use the board name.
