I tried to revert to stock but, after unplugging the battery and also using a paper clip on the jumper while recovering, it shows that “Something went wrong” when I try to boot
Tried to recover ChromeOS using USB stick while unplugging the battery and using a papercilp on the jumper
After finishing recovery it reboot and displays an error screen
Tried many times, the cycle simply repeats which makes me think I bricked my Chromebook
My school Chromebook was randomly deprovisioned so now I have another device to read the logs, I might order a suzy qable if the problem is a firmware problem
Before flash, because that is the point where you need to access the onboard flash chip. In its default configuration the security chip activates CCD when it detects the battery is disconnected. With CCD the security chip accepts external write instructions for the onboard flash chip.
The debricking guide is on Mr. Chromeboxes website, all the instructions should be there.
