Break down with my chromebook
Hi. I tried to install windows on my Chromebook CM3401FF using this link:
After flashing the firmware, I inserted the USB containing windows 11 but chromebook didn’t show up. The keyboard back light turned on but after few seconds it turned off too. When I turn the chromebook on, light indicator turns on but nothing shows on the screen. I tried every possible way, such as turning on with charger plugged, reseting the chromebook but nothing worked. I went to several laptop repair centers but none of them made it work.
What should I do? Does anyone know how can I repair it?
Tnx
did you disable AP RO firmware verification as per the instructions to disable firmware WP?
