So I updated to the most recent MrChromebox firmware and it seems to have broken booting to Linux off of the internal SSD. Previously I was running Ubuntu but after the firmware update, it just broke and spit out the error mentioned in the title. I can boot multiple different distros from a USB drive. I’ve tried Ubuntu(again), Pop_OS(has a specific bug where it can only see 14.9GB of my storage, but that existed before this, so eh), Debian 13, LMDE 7, Linux Mint, Ultramarine Linux, Aurora, and Zorin, but once I’m done with the installation they all suffer from the same error. Their respective entries appear in the boot menu but result in the error, and if I try to go to the boot manager to boot from a file, the menu is blank.
Seeing how I’m not the only one to encounter this issue in the past day, could this be a bug in the firmware that slipped through the latest release, or is it just a coincidence?
The chromebook I use is an ASUS Chromebook Plus CX34, with the boardname Marasov. If anymore info is needed I’ll respond ASAP.
The storage type is an SSD. GNOME Disk Utility specifically gives it the name of MICRON MT128GBCAV2U31, if that helps.
The last firmware version that was working was the MrChromebox-2503.0 release and updating jumped to the latest 2509.1 release as I missed a couple updates, and sadly I didn’t make a backup before updating. Definitely a good idea in hindsight as it would be shorter than downgrading back to the stock firmware then going back to the Chromebox firmware
Alright, after digging for a while longer, I ended up being able to download an older firmware image by looking through sources.sh on your github to see how and where the firmware files are downloaded and then flashed it. Now I’m able to properly boot off of the internal SSD.
If you’d like a log, it’s really no trouble for me to install the newer firmware to get a log then downgrade again. I just need to know how to get the log.
