Booting directly into Linux
Firstly, thanks Mr Chrultrabook and all involved for the excellent documentation. It was a lot of fun putting Mint on my Chromebook Go (Sasuke board). I did not have access to a Suzy Qable at the time, so made do with creating a dual boot environment instead.
Is it possible to boot directly into Linux on powering up, instead of starting at the dev screen and choosing my OS? The option to reformat partition 12 was greyed out for me during the install process, can it be done through Linux disk management after the fact?
Thanks!
You can change the nvram default boot option with `crossystem dev_default_boot=altfw`. You will still have the 30 second timeout though.
Wonderful, thank you! I’ll give that a go.
Sorry for asking a silly question. I’ve run that through the terminal and I can see the various boot options, but it isn’t letting me change the order. Am I missing something obvious? Is this supposed to be run in the ChromeOS side? If so, can I get back to Linux from there?
