I have been using KDE Plasma for a little bit now, I also installed the stoneyridge kernel (latest) and ran the @WeirdTreeThing audio script from GitHub.
My issue is that there is no audio coming out of the headphones, I switched to the headphone output and everything. I ran the debug script but cannot send the tar.gz output due to the forum not accepting it as an “authorized file type”.
(P.S: The speaker output works just fine as expected)
I’ll grab my BARLA and see if I can test. Just two questions.
Is the stoneyridge kernel installed as part of the audio script? I have a BARLA with LMDE 6 on it running the 6.6.23-chrultrabook kernel, should it be running a different one?
Hi! Sorry this is extremely late, I haven’t been able to access the forum for quite some time now, but I haven’t tried a Type C to Audio Jack adapter, as I don’t have access to one. A standard USB Headset works with the BARLA though, so I’m thinking its either the kernel or the audio script not adding the correct config values.
