I have an HP Chromebook with:
- Architecture x86_64
- Board name: BARLA
- CPU model: AMD A4-9120C RADEON R4, 5 COMPUTE CORES 2C+3G
I have not disabled the write protect. My goal is to make the device more flexible: to make it able to boot Linux (OpenSUSE) from USB, while also preserving ChromeOS.
I have put it in Developer Mode, then ran the MrChromebox script and installed the RW_LEGACY firmware. I didn’t see any errors at the time.
Result:
From the developer mode warning screen, when I press Ctrl+L, I see two options:
- U-boot - U-boot bootloader
- TianoCore - TianoCore bootloader
U-boot is functional, but won’t boot my OpenSUSE. TianoCore, however, doesn’t run. If I press 2, I get varying results:
- if I press 2 quickly, I hear one beep (low) and am returned to the developer mode warning screen;
- if I wait a minute then press 2, I hear two beeps (low-high) and then it boots into ChromeOS.
ChromeOS also boots fine if I press Ctrl+D.
Is there anything else I can try to get TianoCore working? Thank you all very much for your time and help.
I notice somebody else had a similar problem with a Lenovo, which sadly doesn’t seem to have ever gotten resolved. ![]()
