I’m having a difficult time here… When I get into my Live distro of Ubuntu 20 (and get past the screen rotation insanity), I bring up up the Terminal to run the firmware script, and I get this…
As you can see, no diag.txt file is found in /tmp - as confirmed in the error messages.
Thank you SO much!
I was about to give up on it altogether.
After removing the snap curl version and using sudo apt install curl I see this from both installed and live version of Ubuntu 22.04.
I ran sudo apt install gcc and that did not help.
the version flashrom used by the script requires a newer libc version that Ubuntu 20xx supports. I recommend live booting 2404
