Backing up a Linux Chromebook conversion to a server that stays in Canada
I help a few small Canadian clients who work on converted Chromebooks running Linux. The machines travel, but the documents, profiles and a known-good firmware copy should not wander onto a random foreign disk. I work from PIPEDA, and when a client is in B.C. or Quebec I also have to respect B.C. privacy rules and Quebec Law 25, so the backup target is a server in Canada.
1. I treat the home folder as the real payload.
2. I keep a labelled copy of the firmware and flash notes on that same Canadian box.
3. I run the first backup over a tunnel, not an open rsync port.
4. I exclude caches and include the bits that would hurt to lose.
5. I encrypt the backup at rest on the server.
6. I test a restore onto a spare conversion before I rely on it.
7. I write down the board name, firmware version and backup schedule.
For those of you with a stable Linux conversion, where do you keep the backup of /home and your flash notes, and do you insist that target stay in a particular country?
Your question has nothing to do with Mrchromebox, how can personal privacy be discussed?
