Audio (Specifically the Microphone part) driver doesn't work
I’m a bit new to modding a chromebook, no clue what to put for most of the system details.
  • Device: Asus C202S (Terra)
  • OS: Windows 10
  • Firmware Type: No Clue
  • Firmware Version: No Clue
  • Internal storage type: Also No Clue
I followed the instructions to mod my Chromebook, all is working smoothly except for one thing; The microphone on my headset won’t register. The audio works well otherwise, with or without the headset I can always hear, it’s just that SPECIFICALLY the microphone won’t connect.
The microphone should actually let me speak into it.
QUICK EXTRA DETAIL
I used tiny 10 for my windows download, I don’t know if that affects it or not but I felt like it should be mentioned.
Tiny10 is not supported. Please use the official version of Microsoft Windows 10
perhaps, but likely has nothing to do with the OP’s issue
see I would but the chromebook has 14 gb of harddrive space, and it would not be able to run it, sorry.
