Acer CYAN type chromebook with coreboot, PopOs 22.04.
Speaker volume is too low, microphone not working.
A bit of background, I’m providing 80 converted Chromebooks to a grant which will distribute them to under served community members here in northern Wisconsin. I’m committed to Ubuntu because that’s what I know how to support.
I installed PopOs hoping that, as a supported distro, I can get some help, and apply what I learn to improve the Ubuntu situation.
Here are the results of running setup-audio:
pre-script:
low max speaker volume
no microphone, either on the settings-> sound page or from a mic test which runs arecord to a tmp file, then aplay on the file
post-script and reboot:
max speaker volume the same, maybe slightly louder
mictest script plays a recording, barely audible
The script runs very quickly and reports:
root@pop-os:~/chromebook-linux-audio# ./setup-audio
WARNING: You may run into audio issues, even after running this script. Please report any issues on github.
Forcing SOF driver in debug mode
Installing UCM configuration
Cloning into ‘/tmp/chromebook-ucm-conf’…
remote: Enumerating objects: 1347, done.
remote: Counting objects: 100% (371/371), done.
remote: Compressing objects: 100% (173/173), done.
remote: Total 1347 (delta 189), reused 343 (delta 173), pack-reused 976 (from 1)
Receiving objects: 100% (1347/1347), 233.68 KiB | 1.71 MiB/s, done.
Resolving deltas: 100% (676/676), done.
Increasing alsa headroom (fixes instability)
Audio installed successfully! Reboot to finish setup.
Is there anything else I can do to get more volume?
Thanks,
Kent
