Audio not working on LMDE after running audio script and installing custom kernel
Output of ls /boot:
config-6.1.0-12-amd64       initrd.img-6.6.58-chrultrabook
config-6.1.0-28-amd64       System.map-6.1.0-12-amd64
config-6.6.58-chrultrabook  System.map-6.1.0-28-amd64
efi                         System.map-6.6.58-chrultrabook
grub                        vmlinuz-6.1.0-12-amd64
initrd.img-6.1.0-12-amd64   vmlinuz-6.1.0-28-amd64
initrd.img-6.1.0-28-amd64   vmlinuz-6.6.58-chrultrabook
Running the audio debug script outputs this (Failed to connect to bus: No medium found does not appear anymore, unlike earlier):
lspci not found. Please install pciutils.
Log collection done.
Please upload "debug-logs.tar.gz" for analysis.
Here is the link for the debug logs
I installed pavucontrol to see the config profiles. Switching the speaker profile from off to “Pro Audio” gives 5 output devices all named Comet Lake PCH-LP cAVS Pro /2/3/4/5
Audio only works on Pro 5-only after setting it as the fallback device
This same issue happened this July and the fix I used then was to install alsa-ucm-conf, which is already preinstalled on LMDE.
Debug logs after switching to “Pro Audio” in Pavucontrol
One other thing is when run the firmware utility script, it outputs this:
MrChromebox Firmware Utility Script starting up
Downloading supporting files...
Downloading required tools...
Getting device/system info...
Flashrom is unable to read current firmware; cannot continue:
flashrom MrChromebox-v1.5.0-rc1 (git:v1.5.0-rc1-4-gd4dc542a09) on Linux 6.6.58-chrultrabook (x86_64)
coreboot table found at 0x99a66000.
Found chipset "Intel Comet Lake U Premium".
Enabling flash write... Warning: Setting BIOS Control at 0xdc from 0x8b to 0x89 failed.
New value is 0x8b.
Error accessing SPIBAR, 0x1000 bytes at 0x00000000fe010000
/dev/mem mmap failed: Operation not permitted
FAILED!
FATAL ERROR!
Error: Programmer initialization failed.
You may need to add 'iomem=relaxed' to your kernel parameters,
or trying running from a Live USB with a more permissive kernel (eg, Ubuntu 23.04+).
If you have UEFI SecureBoot enabled, you need to disable it to run the script/update your firmware.
MrChromebox Firmware Utility setup was unsuccessful
 * diagnosics report has been saved to /tmp/mrchromebox_diag.txt
 * go to https://forum.chrultrabook.com/ for help
I’m not quite sure how to disable Secure Boot.
Edit: fixed links
