And just to recap this is my system info is.
Samsung chromebook pro (Caroline)
Fedora Linux 40 (Workstation Edition) (latest update)
MrChromebox-4.22.4
64-bit os
Intel® Core™ m3-6Y30 × 4
Intel® HD Graphics 515 (SKL GT2)
Wayland
gnome 46
Linux 6.9.8-200.fc40.x86_64 (kernel)
This is arecord -l
**** List of CAPTURE Hardware Devices ****
card 1: avsnau8825 [avs_nau8825], device 1: Headset () []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 4: avsdmic [avs_dmic], device 2: Digital Microphone ()
Subdevices: 1/1
card 5: UC02 [UC02], device 0: USB Audio [USB Audio]
Subdevices: 1/1
This is with converter
Subdevices: 1/1
Subdevices: 1/1
This is with on board audio jack
It says the active card profile for all devices is pro audio, when it should be Default. Try switching them to see if that fixes anything.
Sorry but how do you do this?
I don’t know if you can in gnome audio settings, but you can use pavucontrol instead.
So I installed pavucontrol using Flatpak and tried to use the jack. It did recognize the device, but I did not really hear anything. I heard a little pop and that was it. I made sure that the audio was maxed in settings and alsamixer.
I also checked to make sure the headphones work, and they do. I did not see anything about profiles or Pro Audio or Default in pavucontrol.
Go to the configuration tab and take a screenshot.
Thanks for the update. I updated and applied the audio script, then it works (the speakers).
Hmm, that all looks right. When you plug in headphones to the built in jack, does the device no longer say unplugged?
I cannot hear any audio, but when I unplug or plug in the device, I do hear the sound that plays when a device is connected to a jack.
I don’t know if I ever had a 6.10 kernel I haven’t paid attention.
So this is where I’m at: the laptop does not switch automatically. You have to switch it in settings, but even when you do, it still has no sound even though the volume is up all the way in alsamixer.
