Hi, new Linux user here, I can’t get the audio to work. I followed the steps of the audio script but it is not working. Log:
Hi,
Maybe the same issue then us : https://forum.chrultrabook.com/t/audio-not-working-after-update/2322
Cause of a kernel update
How did you fix the problem there? Should I update the kernel?
The issue is already reported multiple time here WeirdTreeThing/chromebook-linux-audio
I re-installed fedora 40 and didn’t do update for now.
Try fully updating your system and running the script again.
