Audio drivers not woking
I’ve bought and downloaded the audio drivers but I still don’t have audio please someone help
Hi @jiggy, perhaps you havent installed the drivers yet? If your on windows,
  1. open command prompt with administrator.
  2. cd C:\Users\<your username>\<path to file's folder>
  3. PNPUTIL /install /rebook *.inf
If your are on Linux:
  1. Ubuntu/debian:
    sudo apt update && sudo apt upgrade -y
  2. Red Hat Enterprise Linux, CentOS, Fedora, and Oracle Linux:
    sudo yum upgrade
  3. Arch:
    sudo pacman -Syu
-Thanks, happylabdab
You also need the Chromebook ucm config on linux.
I’d recommend against directly installing the inf files. If you want it done correctly, use the installer.
