Audio drivers from coolstar not functioning on my Chromebook
Device**: [ChromeOS board name: (awasuki)]
OS: windows 10 (also tried windows 11)
  • Firmware Type: [UEFI Full ROM only]
  • **Firmware Version: 2512.0
    Internal storage type: emmc
I bought the CoolStar drivers a while back and I wanted to get sound on my asus cx1405cka (Awasuki) and it does not produce any sound at all. I tried different windows versions (10 and 11), but to no avail.
[Briefly describe what is happening]
  1. Tried to install and reinstall it
  2. Tried installing windows 10 and11
  3. Tried different outputs
Audio should have been working but it is not on my asus cx1405cka (AWASUKI)
I don’t know if it’s broken or what because I reinstalled it and nothing Relating to sound happened.
did you properly register the driver and installed the signed license as per the instructions?
I did read the instructions and read the activation as required to make it work, and it just has no sound, it shows the audio thing on, but not any sound.
Also what version of windows does the drivers work on the audio driver? I’m gonna assume 25h2 isn’t supported.
Got it to work, after many failed attempts. Thank you for the help!
perhaps you could share the issue/solution in case others have the same problem?
Excellent work :clap:
You did a good job well done performance.
Can you tell me how you did it? I have the same problem!
