Audio Breaking/Stuttering on Zoom with Coolstar SST (AVS) Audio Driver – Windows 11
  • Device:HP Chromebook (Intel Core i7-8650U) running Windows 11 Pro
  • OS: Windows
  • Firmware Type: Full UEF
  • Firmware Version: coreboot MrChromeboox-2509.1, 13-10-2025
  • Internal storage type: eMMC
I am using an HP Cromebook (Intel Core i7-8650U) running Windows 11 Pro. After installing the Coolstar SST Audio Driver (AVS), the speakers started working and I am able to control/balance the audio.
However, I am experiencing audio breaking/stuttering only during Zoom calls, especially when video is enabled. Check here to see the issue I’m facing.
Troubleshooting already performed:
  • Tested with multiple internet networks / ISPs
  • Issue occurs only in Zoom
  • Other applications play audio normally
  • Output format is fixed at 16-bit, 48000 Hz (CD Quality) and the option is greyed out, so it cannot be changed
My questions:
  1. Could the Coolstar SST (AVS) driver be causing compatibility issues with Zoom?
  2. Is the fixed 16-bit 48 kHz output format a known limitation that could cause audio stuttering during video calls?
  3. Is there a recommended driver version or configuration for stable audio on Windows 11 for this hardware?
Any guidance would be appreciated.
Thank you.
Anyone here to respond?
